メインコンテンツにスキップ
Remington MB4040 Motor Replacement
Cameron Carnahan
Cameron Carnahan とその他 4 人の作成者
最終更新日: July 14, 2024
10 - 15 分
中レベル
The motor controls the blade. If the motor is malfunctioning, the blade will not cut properly.
必要な工具と部品
ツール
もっと見る
  1. Remington MB4040 Motor Replacement, Remove Blade Assembly: 手順 1、 3の画像 1 Remington MB4040 Motor Replacement, Remove Blade Assembly: 手順 1、 3の画像 2 Remington MB4040 Motor Replacement, Remove Blade Assembly: 手順 1、 3の画像 3
    • Press the black button below the blade to remove the blade.
  2. Remington MB4040 Motor Replacement, Remove Back Cover Hardware: 手順 2、 2の画像 1 Remington MB4040 Motor Replacement, Remove Back Cover Hardware: 手順 2、 2の画像 2
    • Place the device so the back of the product is facing up.
    • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
  3. Remington MB4040 Motor Replacement, Remove Front Cover Hardware: 手順 3、 3の画像 1 Remington MB4040 Motor Replacement, Remove Front Cover Hardware: 手順 3、 3の画像 2 Remington MB4040 Motor Replacement, Remove Front Cover Hardware: 手順 3、 3の画像 3
    • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
    • Remove the small clear plastic piece that covers the zoom wheel numbers.
  4. Remington MB4040 Motor Replacement, Front Cover (cont.): 手順 4、 2の画像 1 Remington MB4040 Motor Replacement, Front Cover (cont.): 手順 4、 2の画像 2
    • Remove the two 16.0 mm PH00 screws from the front cover.
    • Use the blue plastic opening tool to pry apart the two halves of the device.
  5. Remington MB4040 Motor Replacement, Blade Button Removal: 手順 5、 2の画像 1 Remington MB4040 Motor Replacement, Blade Button Removal: 手順 5、 2の画像 2
    • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
    • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
  6. Remington MB4040 Motor Replacement, Remove screws attaching the zoom wheel: 手順 6、 2の画像 1 Remington MB4040 Motor Replacement, Remove screws attaching the zoom wheel: 手順 6、 2の画像 2
    • Remove the two 11.0 mm PH00 screws that attach the zoom wheel to the plastic housing.
  7. Remington MB4040 Motor Replacement, Remove Zoom Wheel Assembly: 手順 7、 3の画像 1 Remington MB4040 Motor Replacement, Remove Zoom Wheel Assembly: 手順 7、 3の画像 2 Remington MB4040 Motor Replacement, Remove Zoom Wheel Assembly: 手順 7、 3の画像 3
    • Remove zoom wheel assembly from housing using fingers.
    • Gently remove zoom wheel assembly because the red and black wires are attached and can easily be broken.
    • This assembly also houses the motor.
    • Remove the small black piece of plastic surrounding the zoom wheel. This will be referred to as the slider.
    • When reassembling, make sure the pins on the slider are aligned inside the grooves of the wheel.
  8. Remington MB4040 Motor Replacement, Wheel removal: 手順 8、 3の画像 1 Remington MB4040 Motor Replacement, Wheel removal: 手順 8、 3の画像 2 Remington MB4040 Motor Replacement, Wheel removal: 手順 8、 3の画像 3
    この手順で使用する道具:
    • A pin holds the wheel in place. Using a spudger (preferable metal) and a pair of pliers or tweezers remove the pin to unseat the wheel.
  9. Remington MB4040 Motor Replacement, Screw Removal: 手順 9、 1の画像 1
    • Remove two 3.0 mm PH00 screws from the plastic housing.
  10. Remington MB4040 Motor Replacement, Remove Motor: 手順 10、 2の画像 1 Remington MB4040 Motor Replacement, Remove Motor: 手順 10、 2の画像 2
    • Remove the motor by carefully prying on the back side of the motor with a spudger.
  11. Remington MB4040 Motor Replacement, Remove Wires: 手順 11、 3の画像 1 Remington MB4040 Motor Replacement, Remove Wires: 手順 11、 3の画像 2 Remington MB4040 Motor Replacement, Remove Wires: 手順 11、 3の画像 3
    • Remove the red and black wires from the motor.
    • To install a new motor, the black and red wires must be soldered on.
終わりに
作成者
4人の作成者と共同で作成されました。
Cameron Carnahan
メンバー登録日: 01/20/15
1,082 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 1-5, Blackwell Winter 2015 USF Tampa, Team 1-5, Blackwell Winter 2015人のメンバー
USFT-BLACKWELL-W15S1G5
3 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 21
過去 30 日: 39
今までの合計 3,249
