メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Redmi Note 9 Pro Rear Glass Replacement
必要な工具と部品
  1. Redmi Note 9 Pro Rear Glass Replacement, Heat the rear glass: 手順 1、 1の画像 1
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    FixBotに聞いてみる
    コメントを追加
  2. Redmi Note 9 Pro Rear Glass Replacement, Insert an opening pick: 手順 2、 3の画像 1 Redmi Note 9 Pro Rear Glass Replacement, Insert an opening pick: 手順 2、 3の画像 2 Redmi Note 9 Pro Rear Glass Replacement, Insert an opening pick: 手順 2、 3の画像 3
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  3. Redmi Note 9 Pro Rear Glass Replacement, Slice the adhesive: 手順 3、 2の画像 1 Redmi Note 9 Pro Rear Glass Replacement, Slice the adhesive: 手順 3、 2の画像 2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  4. Redmi Note 9 Pro Rear Glass Replacement, Slice the adhesive: 手順 4、 3の画像 1 Redmi Note 9 Pro Rear Glass Replacement, Slice the adhesive: 手順 4、 3の画像 2 Redmi Note 9 Pro Rear Glass Replacement, Slice the adhesive: 手順 4、 3の画像 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  5. Redmi Note 9 Pro Rear Glass Replacement: 手順 5、 2の画像 1 Redmi Note 9 Pro Rear Glass Replacement: 手順 5、 2の画像 2
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  6. Redmi Note 9 Pro Rear Glass Replacement: 手順 6、 2の画像 1 Redmi Note 9 Pro Rear Glass Replacement: 手順 6、 2の画像 2
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
    FixBotに聞いてみる
    コメントを追加
  7. Redmi Note 9 Pro Rear Glass Replacement, Remove the rear glass: 手順 7、 2の画像 1 Redmi Note 9 Pro Rear Glass Replacement, Remove the rear glass: 手順 7、 2の画像 2
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
11 の人々がこのガイドを完成させました。
Dominik Schnabelrauch
メンバー登録日: 11/23/16
261,795 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
32,107のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 41
過去 30 日: 111
今までの合計 9,113
