メインコンテンツにスキップ
RCA RCT6203W46 Rear Camera Replacement
Grace Chung
Grace Chung とその他 4 人の作成者
最終更新日: December 18, 2016
見積もりなし
中レベル
In order to replace a broken front or rear camera, you will need to follow this guide. There are several steps and you will need to be careful when taking apart this device.
必要な工具と部品
ツール
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
もっと見る
  1. RCA RCT6203W46 Rear Camera Replacement, Front and Rear Camera: 手順 1、 2の画像 1 RCA RCT6203W46 Rear Camera Replacement, Front and Rear Camera: 手順 1、 2の画像 2
    • Make sure the device is off to reduce the chance of an electrical shock. To turn off the device, press and hold the power button.
    • Use a Phillips #00 Screwdriver to unscrew the 4mm (5/32 in.) screws from the back cover of the tablet.
  2. RCA RCT6203W46 Rear Camera Replacement: 手順 2、 2の画像 1 RCA RCT6203W46 Rear Camera Replacement: 手順 2、 2の画像 2
    • Use a spudger to pry the back cover. Start from one edge of the back cover and slide across until the cover is lifted from the tablet body. Repeat for all edges.
  3. RCA RCT6203W46 Rear Camera Replacement: 手順 3、 1の画像 1
    • Open the tablet cover carefully and slowly lengthwise.
    • The keyboard wire ribbon and rear speaker wire should be intact and connected with the back cover.
    • Opening the tablet abruptly may tear or damage cover attachments.
  4. RCA RCT6203W46 Rear Camera Replacement: 手順 4、 1の画像 1
    • Use a spudger to flip up the flap of the ZIF connector that holds the keyboard wire ribbon.
    • Remove the wire ribbon from clamp.
  5. RCA RCT6203W46 Rear Camera Replacement: 手順 5、 2の画像 1 RCA RCT6203W46 Rear Camera Replacement: 手順 5、 2の画像 2
    • Attached to the motherboard you will see two orange ribbons connected to black tabs.
    • Using both hands, place your thumbs gently on the black tab attached to the top and gently lift it.
    • Proceed to slide the orange colored ribbon out from underneath until it is detached from the black tab.
  6. RCA RCT6203W46 Rear Camera Replacement: 手順 6、 1の画像 1
    • Use a spudger to pry and slide underneath the battery to unstick it from the LCD metal plate. It may take a good amount of force to remove.
    • Try to decrease battery deformation by using a spudger rather than prying with your hands.
    • Do not let battery fall back on adhesive, it will stick back onto the LCD metal plate.
    • Be careful to not puncture the battery. The battery may ignite or explode.
  7. RCA RCT6203W46 Rear Camera Replacement: 手順 7、 2の画像 1 RCA RCT6203W46 Rear Camera Replacement: 手順 7、 2の画像 2
    • Gently remove the grey tape that's covering the grey colored wire until it is completely peeled off.
    • Peel off the black piece of tape to remove the antenna.
  8. RCA RCT6203W46 Rear Camera Replacement: 手順 8、 1の画像 1
    • Unscrew three of the 4 mm screws on the motherboard using a Phillips #00 screwdriver.
    • After removing the screws, detach the motherboard from the rest of the tablet. Use a spudger to gently remove it, if necessary.
  9. RCA RCT6203W46 Rear Camera Replacement: 手順 9、 1の画像 1
    • Locate the rear camera and use a prying tool to gently lift the rear camera off of the motherboard.
  10. RCA RCT6203W46 Rear Camera Replacement: 手順 10、 1の画像 1
    • Detach the camera ribbon wire by lifting the tab and pulling the wire. This will leave you with the camera assembly.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Grace Chung
メンバー登録日: 09/21/16
212 ポイント
1ガイドが承認済み
チーム
UC Davis, Team 1-2, Oliver Fall 2016 UC Davis, Team 1-2, Oliver Fall 2016人のメンバー
UCD-OLIVER-F16S1G2
5 メンバー
4のガイドは作成済み
コメント 1 件
Where can I get the main board from RCT6203W46
top - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 20
過去 30 日: 23
今までの合計 336
