メインコンテンツにスキップ
Philips Sonicare ProtectiveClean 6500 Motor Replacement
Liam Casto
Liam Casto とその他 2 人の作成者
最終更新日: June 27, 2024
30分
中レベル
If your Philips Sonicare ProtectiveClean 6500 is showing signs of power (lights turning on) but the toothbrush does not begin to vibrate when the buttons are pressed, you may need to replace the motor. Replacement motors can be found online. This guide will walk you through the steps required to disassemble the toothbrush, remove the motor from the motherboard, and remove any necessary components to replace the motor.
必要な工具と部品
ツール
もっと見る
  1. Philips Sonicare ProtectiveClean 6500 Motor Replacement, Internal Assembly: 手順 1、 3の画像 1 Philips Sonicare ProtectiveClean 6500 Motor Replacement, Internal Assembly: 手順 1、 3の画像 2 Philips Sonicare ProtectiveClean 6500 Motor Replacement, Internal Assembly: 手順 1、 3の画像 3
    • Pry the bottom cap away from the toothbrush body.
    • Pry the bottom cap away from the toothbrush body until it releases.
    • Remove the bottom cap by hand.
  2. Philips Sonicare ProtectiveClean 6500 Motor Replacement: 手順 2、 2の画像 1 Philips Sonicare ProtectiveClean 6500 Motor Replacement: 手順 2、 2の画像 2
    • Use a metal spudger to release the two retaining clips inside the device.
    • The clips release when pried inward.
  3. Philips Sonicare ProtectiveClean 6500 Motor Replacement: 手順 3、 2の画像 1 Philips Sonicare ProtectiveClean 6500 Motor Replacement: 手順 3、 2の画像 2
    • Slide the internal assembly out of the chassis.
  4. Philips Sonicare ProtectiveClean 6500 Motor Replacement, Motor: 手順 4、 2の画像 1 Philips Sonicare ProtectiveClean 6500 Motor Replacement, Motor: 手順 4、 2の画像 2
    • Use an opening tool to gently pry the ribbon cable away from metal motor chassis.
  5. Philips Sonicare ProtectiveClean 6500 Motor Replacement: 手順 5、 2の画像 1 Philips Sonicare ProtectiveClean 6500 Motor Replacement: 手順 5、 2の画像 2
    • Locate the twisted copper wires feeding from the top of the motor to the upper corner of motherboard.
    • Desolder the contact points.
    • Soldering can cause burns and fires. Always solder in a well-ventilated workspace.
  6. Philips Sonicare ProtectiveClean 6500 Motor Replacement: 手順 6、 2の画像 1 Philips Sonicare ProtectiveClean 6500 Motor Replacement: 手順 6、 2の画像 2
    • Desolder the two connections.
  7. Philips Sonicare ProtectiveClean 6500 Motor Replacement: 手順 7、 2の画像 1 Philips Sonicare ProtectiveClean 6500 Motor Replacement: 手順 7、 2の画像 2
    • Turn the assembly over and remove the Phillips screw.
  8. Philips Sonicare ProtectiveClean 6500 Motor Replacement: 手順 8、 3の画像 1 Philips Sonicare ProtectiveClean 6500 Motor Replacement: 手順 8、 3の画像 2 Philips Sonicare ProtectiveClean 6500 Motor Replacement: 手順 8、 3の画像 3
    • Pull the motherboard and motor gently away from the motor chassis.
  9. Philips Sonicare ProtectiveClean 6500 Motor Replacement: 手順 9、 2の画像 1 Philips Sonicare ProtectiveClean 6500 Motor Replacement: 手順 9、 2の画像 2
    • Use a pointed tool to push in the tabs on either side of the white assembly .
    • Pull the wire carrier off of motor chassis.
    • Swap it to the new motor chassis.
終わりに
作成者
2人の作成者と共同で作成されました。
Liam Casto
メンバー登録日: 04/01/24
354 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 1-4, Harley Spring 2024 IUPUI, Team 1-4, Harley Spring 2024人のメンバー
IUPUI-HARLEY-S24S1G4
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 19
今までの合計 168
