Philips Satinelle On/Off Switch Replacement
はじめに
手順 1 に進むIf the epilator is plugged in and the on/ off button does not seem to be working, the switch may be in the wrong position. This guide will help you replace the switch and make sure it is in its right position for the epilator to turn on.
必要な工具と部品
Pull the plastic casing apart with your hands.
That means once the epilator is opened, the same cover cannot be used to enclose the machine??
Renu Singh - 返信
ある他の人がこのガイドを完成しました。
