Philips Norelco BeardTrimmer 3100 Blade Replacement
はじめに
手順 1 に進むIf the blades of your beard trimmer are not working properly, there could be too much hair/dirt between the blades or the blade may have become worn out over time. The blade may need replacement. By following the steps in this guide you will have a new blade installed in no time.
必要な工具と部品
21 の人々がこのガイドを完成させました。
10 件のコメント
what about getting it back togeather
andrewv100 - 返信
Sadly it is impossible to put the parts back together. It isnt just as simple as start with the end. Normally i am quite good with fixing stuff. But this time... maybe because mine is broken? A guide for putting it back together should show me where it g9es wrong. But thanks for the guide anyways, thanks for the time you put into it.
Now I can't get it back :-(
AbdulJalil - 返信
It's easy to get it back.i assembled mine a lot of times... Guys just try
