メインコンテンツにスキップ
Philips HC5450 Disassembly
Jurrie
Jurrie とその他 3 人の作成者
最終更新日: July 15, 2024
8分
簡単
コミュニティメンバーによる寄稿ガイド
A quick disassembly of my Philips HC5450 1415 /A. I needed to revive the batteries.
  1. Philips HC5450 Disassembly, Disassembling a Philips HC5450 1415 /A: 手順 1、 3の画像 1 Philips HC5450 Disassembly, Disassembling a Philips HC5450 1415 /A: 手順 1、 3の画像 2 Philips HC5450 Disassembly, Disassembling a Philips HC5450 1415 /A: 手順 1、 3の画像 3
    • First step is to take off the front like you normally do when cleaning.
  2. Philips HC5450 Disassembly, Take off the silver bezel: 手順 2、 3の画像 1 Philips HC5450 Disassembly, Take off the silver bezel: 手順 2、 3の画像 2 Philips HC5450 Disassembly, Take off the silver bezel: 手順 2、 3の画像 3
    • Pry off the silver bezel. This is attached pretty firmly. Start at the front, and go all the way. The front has tabs with a large hook, so it might only fully disassemble when you have pried it loose a long way and you are able to flex the bezel a little.
    • During this step, I broke the last tab of the silver bezel. Too bad, but the bezel is still firmly attached when reassembling.
  3. Philips HC5450 Disassembly, Take out four T8 screws: 手順 3、 2の画像 1 Philips HC5450 Disassembly, Take out four T8 screws: 手順 3、 2の画像 2
    • Use a T8 Torx driver to remove the four screws.
  4. Philips HC5450 Disassembly, Take apart the body: 手順 4、 3の画像 1 Philips HC5450 Disassembly, Take apart the body: 手順 4、 3の画像 2 Philips HC5450 Disassembly, Take apart the body: 手順 4、 3の画像 3
    • Undo the top part of the black body. I started at the back. It is retained with clips, but is not as firmly attached as the silver bezel.
  5. Philips HC5450 Disassembly, Take out the PCB and batteries: 手順 5、 3の画像 1 Philips HC5450 Disassembly, Take out the PCB and batteries: 手順 5、 3の画像 2 Philips HC5450 Disassembly, Take out the PCB and batteries: 手順 5、 3の画像 3
    • The PCB can now be taken out. The connection to the charging pins is not screwed or soldered, but a U-shaped connector that's just retained by friction.
  6. Philips HC5450 Disassembly, Take out the motor and length-adjustment-assembly: 手順 6、 1の画像 1
    • The assembly is held in place by one Torx T8 screw, identical to those from step 3.
    • The ring of the length-adjustment-assembly can slide down. A little pin-and-spring will fall out - don't loose it! It is used to make the "clicking" feedback when rotating the ring.
    • I did not disassemble this assembly any further.
終わりに
11 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jurrie
メンバー登録日: 05/07/21
667 ポイント
3のガイドは作成済み
8 件のコメント
You helped me replace batteries in otherwise completely fine trimmer. Thanks!
Anyway I also snapped the last silver clip...
Marek Ratvaj - 返信
I joined ifixit just to say thank you for this. Trimmer working perfectly other than a dead battery. I just couldn't see how to get into it until I found this guide. Some advice for others:
Use the pry bar around every part of the bezel. I left the very bottom catch attached and broke it pulling on it. On the other hand, if you have to break one catch, that one is the least important.
A credit card makes a very good pry bar.
This battery seems better than the original in several ways: https://www.amazon.co.uk/dp/B0921ZJX11. It is cheaper. It is easier to install. It will likely be easier to uninstall.
Paul Gardiner - 返信
Thanks for your help. All went as you described it - even the small broken pin :-)
Unfortunately I couldn’t replace the batteries, because they are welded to the PCB. Phillips don’t want the lifespan of their devises to be easily extended…
Cedric Marillat - 返信
Just unsolder it from the circuit board. Obviously that requires a soldering iron and a solder sucker, but those are very useful purchases if you don't already own them. If you then replace with the battery I suggest, you wont even need the solder sucker next time you need to do the job.
Paul Gardiner -
Nice and easy to use guide, with quality images. Do you have an image showing how to reinsert the pin-and-spring please?
Mine sprung out, and can't make out how to add it back!
Tyson - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 42
過去 30 日: 224
今までの合計 7,229
