メインコンテンツにスキップ
Patching a Bicycle Tire Inner Tube
Travis Tonder
Travis Tonder とその他 8 人の作成者
最終更新日: February 19, 2016
10 - 20 分
簡単
You will be taking the wheel off of your bike, removing the tire from the wheel, and patching the hole.
Notes:
  • Make sure that the wheel is fully deflated throughout the process, except for finding the hole.
  • When applying the rubber cement to the hole, the thinner the layer the better, for faster drying.
必要な工具と部品
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. Patching a Bicycle Tire Inner Tube, Rear Wheel: 手順 1、 2の画像 1 Patching a Bicycle Tire Inner Tube, Rear Wheel: 手順 1、 2の画像 2
    • Flip the quick release lever on the wheel.
  2. Patching a Bicycle Tire Inner Tube: 手順 2、 1の画像 1
    • Squeeze the brake arms together and lift the brake cable from the caliper arms.
  3. Patching a Bicycle Tire Inner Tube: 手順 3、 1の画像 1
    • Hold the wheel to the ground, and pull the bike frame up and away to remove the wheel from the bike.
  4. Patching a Bicycle Tire Inner Tube, Inner Tube: 手順 4、 1の画像 1
    • Press the valve core while applying pressure to the tire to deflate the tire.
  5. Patching a Bicycle Tire Inner Tube: 手順 5、 2の画像 1 Patching a Bicycle Tire Inner Tube: 手順 5、 2の画像 2
    • Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel.
    • Slide the lever around the circumference of the wheel to completely remove the tire.
    • Alternatively, if you have multiple tire levers, see if you can clip the first lever to a spoke to keep it in place. Then insert the second lever a few inches away. Clip it to a spoke. Insert the third lever a few more inches along. Take out the second lever and insert it it a few inches past the third. Work along the rim until the tire pops off.
  6. Patching a Bicycle Tire Inner Tube: 手順 6、 1の画像 1
    • Remove the tube by pushing the valve through the hole in the rim and pulling the tube out from under the tire.
  7. Patching a Bicycle Tire Inner Tube, Patching a Bicycle Tire Inner Tube: 手順 7、 1の画像 1
  8. Patching a Bicycle Tire Inner Tube: 手順 8、 2の画像 1 Patching a Bicycle Tire Inner Tube: 手順 8、 2の画像 2
  9. Patching a Bicycle Tire Inner Tube: 手順 9、 1の画像 1
    • Remove the tube by pushing the valve through the hole in the rim and pulling out completely.
  10. Patching a Bicycle Tire Inner Tube: 手順 10、 2の画像 1 Patching a Bicycle Tire Inner Tube: 手順 10、 2の画像 2
    • Locate the leak by first over inflating the tire.
    • Place the tire under water and look for bubbles to find the leak.
  11. Patching a Bicycle Tire Inner Tube: 手順 11、 1の画像 1
    • Mark the hole with a marker, and completely deflate the tire.
  12. Patching a Bicycle Tire Inner Tube: 手順 12、 1の画像 1
    • Select a patch kit that you will use to patch the hole. Try to pick a patch that is appropriate for the size of the hole.
  13. Patching a Bicycle Tire Inner Tube: 手順 13、 1の画像 1
    • Clean the area near the hole with soap and water, then dry it thoroughly.
    • Rough up the area around the hole with an abrasive surface such as sand paper until the area around the leak loses its shine.
  14. Patching a Bicycle Tire Inner Tube: 手順 14、 1の画像 1
    • Apply rubber cement to an area around the hole that is bigger than the patch to ensure that the patch bonds completely.
  15. Patching a Bicycle Tire Inner Tube: 手順 15、 1の画像 1
    • Apply the patch to the area.
  16. Patching a Bicycle Tire Inner Tube: 手順 16、 1の画像 1
    • Apply pressure to the patch until the rubber cement is dry.
終わりに
To reassemble your wheel, follow these instructions in reverse order starting at step three.
6 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Travis Tonder
メンバー登録日: 10/05/10
3,210 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 5-13, Maness Fall 2010 Cal Poly, Team 5-13, Maness Fall 2010人のメンバー
CPSU-MANESS-F10S5G13
4 メンバー
17のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 4,155
