メインコンテンツにスキップ
Panasonic Lumix DMC-FX01 Camera Lens Replacement
Caleb Fink
Caleb Fink とその他 9 人の作成者
最終更新日: January 3, 2023
45分 - 1時間
中レベル
アクションショット
If your Panasonic Lumix DMC-FX01 is unable to take pictures with the lens or the lens refuses to open, this guide will show you how to replace it. A camera lens is an important component to a digital camera. Without it, the image you want to capture will not be possible.
Smaller digital cameras like this one come with very small pieces that you will need to remove. As you will see later in the guide, it is important to be a delicate as possible with the pieces to ensure you do not cause any more damage to the broken item.
Before you begin, check the battery connecter to see if any debris is preventing the battery to make the lens work (this is a common reason the lens will not work).
Once you have confirmed that the lens is not working, begin this guide.
必要な工具と部品
ツール
  1. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Battery: 手順 1、 1の画像 1
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 2、 1の画像 1
    • Open the battery latch, and slide the battery release lever to the right.
  3. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 3、 1の画像 1
    • Remove the battery from the camera.
  4. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Rear Casing: 手順 4、 1の画像 1
    • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 5、 1の画像 1
    • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 6、 2の画像 1 Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 6、 2の画像 2
    • Remove the left side casing.
  7. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 7、 1の画像 1
    • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
  8. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 8、 1の画像 1
    • Remove the bottom right panel.
  9. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 9、 2の画像 1 Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 9、 2の画像 2
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  10. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Front Casing: 手順 10、 2の画像 1 Panasonic Lumix DMC-FX01 Camera Lens Replacement, Front Casing: 手順 10、 2の画像 2
    • Remove the two black 5.4 mm screws that hold in the front faceplate using a Phillips #00 screwdriver.
    • There may be a third screw the the right of the lens assembly.
  11. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 11、 3の画像 1 Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 11、 3の画像 2 Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 11、 3の画像 3
    • Carefully remove the upper assembly, which houses the buttons and the flash battery.
  12. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 12、 1の画像 1
    • Carefully remove the front casing after verifying that the thin plastic around the lens is not still attached.
  13. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Lens Assembly: 手順 13、 2の画像 1 Panasonic Lumix DMC-FX01 Camera Lens Replacement, Lens Assembly: 手順 13、 2の画像 2
    • Remove the three black 5mm screws attached to the lens frame.
  14. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 14、 1の画像 1
    • Remove the lens frame.
  15. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 15、 1の画像 1
    • Lift out the circuit board as shown.
  16. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 16、 2の画像 1 Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 16、 2の画像 2
    • Lift the two black latches that hold the connector ribbons in place.
    • Disconnect the two ribbons.
  17. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 17、 1の画像 1
    • Remove the lens assembly as shown.
  18. Panasonic Lumix DMC-FX01 Camera Lens Replacement, Camera Lens: 手順 18、 1の画像 1
    • Remove four 4 mm screws from the lens assembly using the Phillips #00 screwdriver.
  19. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 19、 2の画像 1 Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 19、 2の画像 2
    • Separate the fixed frame unit from the main lens assembly.
    • Separate the direct frame unit from the main lens assembly.
  20. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 20、 1の画像 1
    • Remove the first lens frame from the lens assembly.
  21. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 21、 1の画像 1
    • Detach the second frame unit from the lens assembly.
  22. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 22、 1の画像 1
    • Remove the 4m m screw from the lens housing using the Phillips #00 screwdriver.
  23. Panasonic Lumix DMC-FX01 Camera Lens Replacement: 手順 23、 1の画像 1
    • Separate the lens housing.
    • Replace the lens by gently prying away from the assembly.
終わりに
4 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Caleb Fink
メンバー登録日: 10/11/10
191 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 9-22, Regan Fall 2010 Cal Poly, Team 9-22, Regan Fall 2010人のメンバー
CPSU-REGAN-F10S9G22
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 27
今までの合計 12,973
