メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
OnePlus 9 Pro Screen Replacement
必要な工具と部品
  1. OnePlus 9 Pro Screen Replacement, Rear Glass: 手順 1、 1の画像 1
    • For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
    • Unplug any chargers/peripheries and power off your phone.
    FixBotに聞いてみる
    コメントを追加
  2. OnePlus 9 Pro Screen Replacement: 手順 2、 1の画像 1
    FixBotに聞いてみる
    コメントを追加
  3. OnePlus 9 Pro Screen Replacement: 手順 3、 2の画像 1 OnePlus 9 Pro Screen Replacement: 手順 3、 2の画像 2
    • Use a hair dryer to lightly heat the perimeter of the rear glass.
    • Additionally, heat the top-right corner, as there is adhesive further inside of phone in that one spot.
    • Do not hold the hair dryer in one spot on the phone for too long to prevent damage to internal parts of the phone.
    FixBotに聞いてみる
    コメントを追加
  4. OnePlus 9 Pro Screen Replacement: 手順 4、 1の画像 1
    • Apply a suction handle as close to the bottom edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the glass and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive.
    • Insert an opening pick into the gap.
    FixBotに聞いてみる
    コメントを追加
  5. OnePlus 9 Pro Screen Replacement: 手順 5、 1の画像 1
    • Slide the opening pick around the perimeter of the rear glass to slice the adhesive.
    • Insert additional opening picks as you slice the adhesive to prevent the adhesive from resealing.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your hair dryer to reheat it.
    FixBotに聞いてみる
    コメントを追加
  6. OnePlus 9 Pro Screen Replacement: 手順 6、 2の画像 1 OnePlus 9 Pro Screen Replacement: 手順 6、 2の画像 2
    • Carefully lift the rear glass up and off of the phone.
    • During reassembly secure the rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
    FixBotに聞いてみる
    コメントを追加
  7. OnePlus 9 Pro Screen Replacement, Bottom Loudspeaker: 手順 7、 2の画像 1 OnePlus 9 Pro Screen Replacement, Bottom Loudspeaker: 手順 7、 2の画像 2
    • Use one of the opening picks to remove the adhesive on the lower part of the wireless charging cable
    FixBotに聞いてみる
    コメントを追加
  8. OnePlus 9 Pro Screen Replacement: 手順 8、 3の画像 1 OnePlus 9 Pro Screen Replacement: 手順 8、 3の画像 2 OnePlus 9 Pro Screen Replacement: 手順 8、 3の画像 3
    • Unplug the press connector ribbon cable attached to the flash module by inserting a spudger under the bottom edge and prying straight up.
    • Use an opening pick to remove the flash module by the camera.
    • Use a Phillips #000 screwdriver to remove the eleven 4.9 mm-long screws holding the motherboard cover to the phone.
    • Use an opening pick to pry off the motherboard cover.
    FixBotに聞いてみる
    コメントを追加
  9. OnePlus 9 Pro Screen Replacement: 手順 9、 1の画像 1
    • Use a Phillips #000 screwdriver to remove five screws that secure the lower daughterboard cover.
    • Two of the screws have a white head and are 4.8 mm-long. They go in the bottom right corner of the daughter and mother board.
    • The other three screws are black and are also 4.8 mm-long.
    FixBotに聞いてみる
    コメントを追加
  10. OnePlus 9 Pro Screen Replacement: 手順 10、 2の画像 1 OnePlus 9 Pro Screen Replacement: 手順 10、 2の画像 2
    • Disconnect the two interconnect cables by inserting a spudger under each lip and prying straight up.
    FixBotに聞いてみる
    コメントを追加
  11. OnePlus 9 Pro Screen Replacement: 手順 11、 1の画像 1
    • Remove the three screws from the loudspeaker using a Phillips #000 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  12. OnePlus 9 Pro Screen Replacement: 手順 12、 1の画像 1
    • Use the spudger to pry up and remove the loudspeaker.
    FixBotに聞いてみる
    コメントを追加
  13. OnePlus 9 Pro Screen Replacement, Battery: 手順 13、 3の画像 1 OnePlus 9 Pro Screen Replacement, Battery: 手順 13、 3の画像 2 OnePlus 9 Pro Screen Replacement, Battery: 手順 13、 3の画像 3
    • Use an opening pick or tweezers to carefully peel back the adhesive on the bottom of the wireless charging module.
    FixBotに聞いてみる
    コメントを追加
  14. OnePlus 9 Pro Screen Replacement: 手順 14、 3の画像 1 OnePlus 9 Pro Screen Replacement: 手順 14、 3の画像 2 OnePlus 9 Pro Screen Replacement: 手順 14、 3の画像 3
    • Pry on the bottom of the flash module off using a pick and use tweezers to get under the module without ripping it.
    • Be careful unplugging the module as the cable is very delicate.
    FixBotに聞いてみる
    コメントを追加
  15. OnePlus 9 Pro Screen Replacement: 手順 15、 1の画像 1
    • Use a Phillips #000 screwdriver to remove the eleven 4.8 mm-long screws securing the motherboard cover.
    FixBotに聞いてみる
    コメントを追加
  16. OnePlus 9 Pro Screen Replacement: 手順 16、 3の画像 1 OnePlus 9 Pro Screen Replacement: 手順 16、 3の画像 2 OnePlus 9 Pro Screen Replacement: 手順 16、 3の画像 3
    • Pry around the phone with picks to remove the motherboard cover.
    FixBotに聞いてみる
    コメントを追加
  17. OnePlus 9 Pro Screen Replacement: 手順 17、 1の画像 1
    • Lift off the motherboard cover.
    FixBotに聞いてみる
    コメントを追加
  18. OnePlus 9 Pro Screen Replacement: 手順 18、 2の画像 1 OnePlus 9 Pro Screen Replacement: 手順 18、 2の画像 2
    • Pry up and disconnect the press connector ribbon cable in the top right with a spudger.
    • Make sure not to damage them in the process.
    FixBotに聞いてみる
    コメントを追加
  19. OnePlus 9 Pro Screen Replacement: 手順 19、 3の画像 1 OnePlus 9 Pro Screen Replacement: 手順 19、 3の画像 2 OnePlus 9 Pro Screen Replacement: 手順 19、 3の画像 3
    • Use a spudger to disconnect the two interconnect cables from the motherboard by prying the connector straight up from its socket.
    FixBotに聞いてみる
    コメントを追加
  20. OnePlus 9 Pro Screen Replacement: 手順 20、 2の画像 1 OnePlus 9 Pro Screen Replacement: 手順 20、 2の画像 2
    • Take care not to bend or puncture battery during the removal procedure—a bent battery may leak dangerous chemicals or cause a fire.
    • Remove the battery from the phone by slowly pulling up on the red tabs.
    • If you're having trouble lifting the battery out of its recess, apply a heated iOpener to the screen side for two minutes to loosen the battery adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    FixBotに聞いてみる
    コメントを追加
  21. OnePlus 9 Pro Screen Replacement, Screen: 手順 21、 2の画像 1 OnePlus 9 Pro Screen Replacement, Screen: 手順 21、 2の画像 2
    • Use the spudger to unplug the ribbon cable that connects the screen to the rest of the phone.
    FixBotに聞いてみる
    コメントを追加
  22. OnePlus 9 Pro Screen Replacement: 手順 22、 1の画像 1
    • Place the suction cup on the glass towards the bottom of the screen.
    FixBotに聞いてみる
    コメントを追加
  23. OnePlus 9 Pro Screen Replacement: 手順 23、 1の画像 1
    • Heat the adhesive holding the screen onto the phone by using the heat gun on the edges of the screen.
    • Be sure to use caution when using the heat gun.
    FixBotに聞いてみる
    コメントを追加
  24. OnePlus 9 Pro Screen Replacement: 手順 24、 3の画像 1 OnePlus 9 Pro Screen Replacement: 手順 24、 3の画像 2 OnePlus 9 Pro Screen Replacement: 手順 24、 3の画像 3
    • Put the jimmy into the bottom edge of the screen.
    • Use an opening pick to slice the adhesive, and place opening picks around the perimeter as you slice to avoid the adhesive from resealing.
    • Reheat the screen as needed.
    FixBotに聞いてみる
    コメントを追加
  25. OnePlus 9 Pro Screen Replacement: 手順 25、 2の画像 1 OnePlus 9 Pro Screen Replacement: 手順 25、 2の画像 2
    • Carefully pull up on the suction cup to pull the screen away from the phone.
    FixBotに聞いてみる
    コメントを追加
終わりに
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Averie
メンバー登録日: 02/17/25
291 ポイント
2のガイドは作成済み
チーム
University of Memphis, Team 1-1, Sneed Spring 2025 University of Memphis, Team 1-1, Sneed Spring 2025人のメンバー
UM-SNEED-S25S1G1
4 メンバー
15のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 60
過去 30 日: 256
今までの合計 2,825
