メインコンテンツにスキップ
Overview of the Nokia N95 hardware with circuit diagrams and labeled chips. See www.phoneWreck.com for more detailed information on the Nokia N95 and other devices.
Nokia produced this disassembly guide, which you can also use to help disassemble your phone.
必要な工具と部品
ツール
もっと見る
この分解は修理ガイドでは ありません。 お持ちのNokia N95を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Nokia N95 Teardown, Nokia N95 Teardown: 手順 1、 1の画像 1
    • It should be noted that this model is the N95-1 with the expandable MicroSD card storage.
    • The N95 was a tough one to crack open since there were more mechanical parts than a traditional smartphone, with dual-sliding modes. This one was totally worth it though, as we were treated to a bevy of ICs, resistors, and the whole lot of circuitry.
  2. Nokia N95 Teardown: 手順 2、 2の画像 1 Nokia N95 Teardown: 手順 2、 2の画像 2
    • It’s got three different memory units, one Spansion and two Samsungs, which we’ve made logical guesses as to which processor they served.
    • It runs an unmarked TI baseband processor and a TI OMAP2420 apps processor.
    • The dual processor makes for relatively complex circuitry, but the performance capabilities of the N95 really demonstrate the prowess of having an extra applications processor to do the dirty work.
  3. Nokia N95 Teardown: 手順 3、 1の画像 1
    • The back of the main PCB is shown below. The primary IC diagram can be found here.
    • The interesting thing about the N95 is that since the screen is on a separate mount, both sides of the PCB can be used. This, however, does cause the device to be a little bulkier than its candybar-form-factored friends.
  4. Nokia N95 Teardown: 手順 4、 3の画像 1 Nokia N95 Teardown: 手順 4、 3の画像 2 Nokia N95 Teardown: 手順 4、 3の画像 3
    • Finally, the camera module. This 5.0MP camera, with the image sensor developed by Micron Technologies, was the leading cameraphone back in the day, and its beastly size definitely attests to that.
    • For a full bill of materials and even more pictures, visit the Nokia N95 wiki page.
作成者
6人の作成者と共同で作成されました。
drwreck
メンバー登録日: 11/11/09
1,446 ポイント
11のガイドは作成済み
2件のガイドコメント
Buenos días, estoy buscando la carcasa original de este modelo en particular. ¿Alguno me puede ayudar?
vrendon1971@hotmail.com
vrendon1971 - 返信
Here is a link to the official Nokia N95 service manual. You can display it, then save it as a PDF file.
https://manualzz.com/doc/6309090/nokia-n...
mraroid
jack honeycutt - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 16
過去 30 日: 100
今までの合計 60,321
