メインコンテンツにスキップ
Nokia E61i Motherboard Replacement
Christopher Patton
Christopher Patton とその他 7 人の作成者
最終更新日: January 10, 2025
15 - 20 分
簡単
空欄の手順
アクションショット
高画質の画像が必要
より良い紹介部分
必要な工具と部品
ツール
もっと見る
  1. Nokia E61i Motherboard Replacement, Battery: 手順 1、 2の画像 1 Nokia E61i Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • First, gather all necessary tools.
    • Remove the back cover to access the battery by pushing the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing down on the tab.
  2. Nokia E61i Motherboard Replacement: 手順 2、 1の画像 1
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Nokia E61i Motherboard Replacement: 手順 3、 1の画像 1
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Nokia E61i Motherboard Replacement, Front Cover: 手順 4、 2の画像 1 Nokia E61i Motherboard Replacement, Front Cover: 手順 4、 2の画像 2
    • To remove the top of the back cover, pry the sides and pop it off.
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Nokia E61i Motherboard Replacement: 手順 5、 1の画像 1
    • Remove the cover by pulling it up and off.
  6. Nokia E61i Motherboard Replacement, Display: 手順 6、 2の画像 1 Nokia E61i Motherboard Replacement, Display: 手順 6、 2の画像 2
    • Take off the casing and keyboard.
    • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
    • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
    • Lift the ribbon, disconnecting contact with the motherboard.
    • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
  7. Nokia E61i Motherboard Replacement: 手順 7、 2の画像 1 Nokia E61i Motherboard Replacement: 手順 7、 2の画像 2
    • Gently pull the screen off of the phone.
    • Be sure not to rip the sticker that connects the display and the motherboard.
    • Pull the silver case off to completely free the cracked or damaged screen.
  8. Nokia E61i Motherboard Replacement, Motherboard: 手順 8、 3の画像 1 Nokia E61i Motherboard Replacement, Motherboard: 手順 8、 3の画像 2 Nokia E61i Motherboard Replacement, Motherboard: 手順 8、 3の画像 3
    • Pull the green motherboard from the back casing.
終わりに
作成者
7人の作成者と共同で作成されました。
Christopher Patton
メンバー登録日: 04/07/11
208 ポイント
12のガイドは作成済み
チーム
Cal Poly, Team 9-63, Walters Spring 2011 Cal Poly, Team 9-63, Walters Spring 2011人のメンバー
CPSU-WALTERS-S11S9G63
5 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 6
今までの合計 1,619
