メインコンテンツにスキップ
Nokia Classic 2600c-2b Camera Replacement
Ian VanZandt
Ian VanZandt とその他 6 人の作成者
最終更新日: December 18, 2023
30分
中レベル
高画質の画像が必要
This guide will show how to replace the camera in a Nokia Classic 2600c-2b model phone. The camera of the phone allows the phone to take pictures. The phone camera is made out of glass and other fragile materials which can break easily so do make sure that you handle the camera component with care as to not break it. Also be careful when removing the battery as it does contain lithium ion, which can become flammable if punctured or if it is damaged in any way.
必要な工具と部品
ツール
  1. Nokia Classic 2600c-2b Camera Replacement, Camera: 手順 1、 2の画像 1 Nokia Classic 2600c-2b Camera Replacement, Camera: 手順 1、 2の画像 2
    • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Pull the phone apart from the bottom, keeping the button pressed down.
    • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
  2. Nokia Classic 2600c-2b Camera Replacement: 手順 2、 1の画像 1
    • Remove the back cover to expose the battery. Put the plastic cover in a safe location for later.
  3. Nokia Classic 2600c-2b Camera Replacement: 手順 3、 2の画像 1 Nokia Classic 2600c-2b Camera Replacement: 手順 3、 2の画像 2
    • Place a finger or plastic opening tool in the gap between the battery and the phone.
    • Gently lift the battery out by putting your finger in the small indent.
  4. Nokia Classic 2600c-2b Camera Replacement: 手順 4、 2の画像 1 Nokia Classic 2600c-2b Camera Replacement: 手順 4、 2の画像 2
    • Locate the plastic latches on the left and right sides of the phone.
    • Insert the plastic opening tool or a fingernail into each latch and pry them open individually.
    • CAUTION! Some force is required.
  5. Nokia Classic 2600c-2b Camera Replacement: 手順 5、 1の画像 1
    • Remove the faceplate with the number pad attached and put the faceplate to the side.
  6. Nokia Classic 2600c-2b Camera Replacement: 手順 6、 1の画像 1
    • Turn the faceplate so the number pad faces downward.
    • Lift the number pad out of the faceplate.
  7. Nokia Classic 2600c-2b Camera Replacement: 手順 7、 2の画像 1 Nokia Classic 2600c-2b Camera Replacement: 手順 7、 2の画像 2
    • Remove the six screws along the edges of the phone using a Torx 5 screwdriver.
  8. Nokia Classic 2600c-2b Camera Replacement: 手順 8、 2の画像 1 Nokia Classic 2600c-2b Camera Replacement: 手順 8、 2の画像 2
    • Locate the orange ribbon tape connecting the metal display plate to the motherboard.
    • Lift the black latch attaching the tape to the motherboard.
    • Gently pull the tape out of the latch slot to remove the metal display.
  9. Nokia Classic 2600c-2b Camera Replacement: 手順 9、 2の画像 1 Nokia Classic 2600c-2b Camera Replacement: 手順 9、 2の画像 2
    • Using the plastic opening tool, gently pry off the motherboard from the plastic shell. Place the metal display in a safe location for reassembly.
    • CAUTION! When pulling the motherboard out, be careful not to damage the battery under the lower left hand corner of the motherboard.
  10. Nokia Classic 2600c-2b Camera Replacement: 手順 10、 1の画像 1
    • Turn the motherboard over and locate the orange ribbon tape connecting the display to the motherboard.
    • Gently pull the tape up to remove the display.
  11. Nokia Classic 2600c-2b Camera Replacement: 手順 11、 1の画像 1
    • Locate the camera component in the plastic shell removed from underneath the motherboard (It is one piece).
    • Gently pull out the camera component using either a finger or plastic opening tool.
終わりに
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Ian VanZandt
メンバー登録日: 02/14/12
675 ポイント
5のガイドは作成済み
チーム
James Madison, Team 3-1, Klein Spring 2012 James Madison, Team 3-1, Klein Spring 2012人のメンバー
JMU-KLEIN-S12S3G1
3 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 7
今までの合計 1,294
