メインコンテンツにスキップ
Nokia 6590i Battery Charger Connector Replacement
Colby Leslie
Colby Leslie とその他 2 人の作成者
最終更新日: February 19, 2016
10 - 15 分
中レベル
アクションショット
作成中の学生
This Guide will show how the remove the phone's battery charger connector.
必要な工具と部品
ツール
  1. Nokia 6590i Battery Charger Connector Replacement, Battery: 手順 1、 1の画像 1
    • Before taking apart your Nokia 6590i, you will need to purchase a new battery. You can find them at Amazon, Walmart, or any cell phone repair store.
    • For reference, pictured here is a photo of a new battery for the Nokia 6590i.
    • Most new batteries will have a price range of $10 to $30.
  2. Nokia 6590i Battery Charger Connector Replacement: 手順 2、 2の画像 1 Nokia 6590i Battery Charger Connector Replacement: 手順 2、 2の画像 2
    • After purchasing a new battery, we can begin the replacement.
    • First, press the button on the bottom of the rear cover.
    • Second, keep the button pressed while pulling the cover downward to remove the back cover.
    • Third, lift the cover off.
  3. Nokia 6590i Battery Charger Connector Replacement: 手順 3、 1の画像 1
    • Then, to remove the old battery, push it down from the top and pull it out.
    • To install the new battery, just follow this guide in reverse order!
  4. Nokia 6590i Battery Charger Connector Replacement, Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: 手順 4、 1の画像 1
    • Grip the front cover from the bottom.
  5. Nokia 6590i Battery Charger Connector Replacement: 手順 5、 1の画像 1
    • Lift the front cover off.
  6. Nokia 6590i Battery Charger Connector Replacement: 手順 6、 1の画像 1
    • Remove the six screws using a T6 torx screwdriver.
  7. Nokia 6590i Battery Charger Connector Replacement: 手順 7、 1の画像 1
    • Insert spudger along edge of assembly and gently lift assembly away from case
  8. Nokia 6590i Battery Charger Connector Replacement: 手順 8、 1の画像 1
    • Remove assembly from phone
  9. Nokia 6590i Battery Charger Connector Replacement, Logic Board: 手順 9、 1の画像 1
    • The logic board now sits on top of the phone.
  10. Nokia 6590i Battery Charger Connector Replacement: 手順 10、 1の画像 1
    • Lift the logic board out of the phone.
  11. Nokia 6590i Battery Charger Connector Replacement, Battery Charger Connector: 手順 11、 1の画像 1
    • Locate battery charger connector
  12. Nokia 6590i Battery Charger Connector Replacement: 手順 12、 1の画像 1
    • Grasp top and bottom of battery charger connector on the left side
  13. Nokia 6590i Battery Charger Connector Replacement: 手順 13、 1の画像 1
    • Lift out the battery charger connector
終わりに
作成者
2人の作成者と共同で作成されました。
Colby Leslie
メンバー登録日: 10/05/10
13 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 22-3, Maness Fall 2010 Cal Poly, Team 22-3, Maness Fall 2010人のメンバー
CPSU-MANESS-F10S22G3
4 メンバー
9のガイドは作成済み
0ガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,894
