Nokia 6030 Logic Board Replacement
はじめに
手順 1 に進むReplacing the logic board.
必要な工具と部品
Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
Insert your two fingers under the two tabs found at the top of the phone underneath the black casing, then pull the casing up and slide it out slowly.
Remove the six screws found along the frame of the phone with a T6 Torx screwdriver and put them to the side.
ある他の人がこのガイドを完成しました。
