メインコンテンツにスキップ
Nokia 6010 screen and speaker replacement
Nicholas Hanne
Nicholas Hanne とその他 3 人の作成者
最終更新日: September 29, 2017
5分
簡単
Use this guide to remove and replace the Nokia 6010's LCD screen and speaker.
必要な工具と部品
ツール
  1. Nokia 6010 screen and speaker replacement, Battery: 手順 1、 3の画像 1 Nokia 6010 screen and speaker replacement, Battery: 手順 1、 3の画像 2 Nokia 6010 screen and speaker replacement, Battery: 手順 1、 3の画像 3
    • Press the small tab on the bottom of the back of the phone.
    • Push the back case upward towards the power button. The back case will then pop off.
    • It requires some force, so be careful.
  2. Nokia 6010 screen and speaker replacement: 手順 2、 2の画像 1 Nokia 6010 screen and speaker replacement: 手順 2、 2の画像 2
    • Lift the battery near the bottom and pry up.
  3. Nokia 6010 screen and speaker replacement, SIM Card: 手順 3、 1の画像 1
    • With one hand, press the ridged tab near the visible side of the SIM card.
    • Slide the card out with your other hand.
    Thank you ! The instruction was really easy to understand
    Tobi Hunt - 返信
  4. Nokia 6010 screen and speaker replacement, Keypad: 手順 4、 2の画像 1 Nokia 6010 screen and speaker replacement, Keypad: 手順 4、 2の画像 2
    • Grip the phone on either the sides, the top, or the bottom.
    • Pull the front case away from the rest of the phone.
    • There are no special tabs to keep it in place so it should wiggle free easily.
  5. Nokia 6010 screen and speaker replacement: 手順 5、 1の画像 1
    • Lift the keypad away from the body of the phone.
    • The keypad is the rubber-backed piece with the number keys.
  6. Nokia 6010 screen and speaker replacement, LCD Screen and Speaker: 手順 6、 2の画像 1 Nokia 6010 screen and speaker replacement, LCD Screen and Speaker: 手順 6、 2の画像 2
    • Remove the six screws around the front of the phone body with a T6 screwdriver.
  7. Nokia 6010 screen and speaker replacement: 手順 7、 3の画像 1 Nokia 6010 screen and speaker replacement: 手順 7、 3の画像 2 Nokia 6010 screen and speaker replacement: 手順 7、 3の画像 3
    • Insert your finger underneath the speaker piece and pry away from the phone body.
    • The plastic layer containing the LCD screen and speaker takes some force to remove.
    • There are 4 plastic tabs which keep it in place, but they are hard to press. Be careful and go tab by tab or use a spudger if you are nervous about using too much force.
    • The LCD and the speaker are attached to the same piece and must be replaced together.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Nicholas Hanne
メンバー登録日: 01/20/10
129 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 14-45, Regan Winter 2010 Cal Poly, Team 14-45, Regan Winter 2010人のメンバー
CPSU-REGAN-W10S14G45
5 メンバー
16のガイドは作成済み
1ガイドコメント
Greatly appreciated !!!
Tobi Hunt - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 4,293
