Nokia 3360 Cover Plate Replacement
はじめに
手順 1 に進むThis guide shows how remove and replace a damaged cover plate.
Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
Lift the back plate off the phone.
Use finger nails of your thumbs to gently pull apart the face plate.
While the face plate is pulled apart, use index fingers to pull inner case towards you.
Separate faceplate and inner case.
2 の人々がこのガイドを完成させました。
