メインコンテンツにスキップ
Nokia 3310 3G Keyboard Replacement
Aaron LeBlanc
Aaron LeBlanc とその他 3 人の作成者
最終更新日: April 5, 2023
20分
中レベル
This guide shows a step by step guide to fully access the keyboard, to clean it if it is sticking or completely replace the keypad if it is broken.
必要な工具と部品
ツール
もっと見る
  1. Nokia 3310 3G Keyboard Replacement, Battery: 手順 1、 2の画像 1 Nokia 3310 3G Keyboard Replacement, Battery: 手順 1、 2の画像 2
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. Nokia 3310 3G Keyboard Replacement: 手順 2、 2の画像 1 Nokia 3310 3G Keyboard Replacement: 手順 2、 2の画像 2
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
  3. Nokia 3310 3G Keyboard Replacement, Frame: 手順 3、 3の画像 1 Nokia 3310 3G Keyboard Replacement, Frame: 手順 3、 3の画像 2 Nokia 3310 3G Keyboard Replacement, Frame: 手順 3、 3の画像 3
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
  4. Nokia 3310 3G Keyboard Replacement, Motherboard: 手順 4、 3の画像 1 Nokia 3310 3G Keyboard Replacement, Motherboard: 手順 4、 3の画像 2 Nokia 3310 3G Keyboard Replacement, Motherboard: 手順 4、 3の画像 3
    • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
  5. Nokia 3310 3G Keyboard Replacement, Keyboard: 手順 5、 3の画像 1 Nokia 3310 3G Keyboard Replacement, Keyboard: 手順 5、 3の画像 2 Nokia 3310 3G Keyboard Replacement, Keyboard: 手順 5、 3の画像 3
    • Using a spudger, unclip the bottom left snap to unplug the keyboard. The image shows the motherboard rotated 90 degrees counterclockwise
    I need this keypad flex or full keypad with
    ad k - 返信
    I'm from India and I need it very
    ad k - 返信
  6. Nokia 3310 3G Keyboard Replacement: 手順 6、 1の画像 1
    • Using your thumb, push the tab on the right side of the motherboard over to the right and then push downward to unclip the keyboard. It should fall away.
終わりに
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Aaron LeBlanc
メンバー登録日: 10/24/18
735 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S3-G3, Peak Fall 2018 UMass Dartmouth, Team S3-G3, Peak Fall 2018人のメンバー
UMASSD-PEAK-F18S3G3
3 メンバー
16のガイドは作成済み
1件のガイドコメント
Very useful and to the point
OrangeShoe - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 51
今までの合計 2,477
