メインコンテンツにスキップ
Nokia 3120 Speaker Replacement
Pierre Tong
Pierre Tong とその他 6 人の作成者
最終更新日: September 9, 2017
見積もりなし
中レベル
This guide will disassemble the phone's cover plate and key pad to reveal the interface in order to work on the phone's speaker. This guide requires a moderate amount of work as the small parts are tricky to remove.
必要な工具と部品
ツール
  • Probe and Pick Set
    Probe and Pick Set
  • Spudger
    Spudger
  • 64 Bit Driver Kit
もっと見る
  1. Nokia 3120 Speaker Replacement, Battery Installation: 手順 1、 3の画像 1 Nokia 3120 Speaker Replacement, Battery Installation: 手順 1、 3の画像 2 Nokia 3120 Speaker Replacement, Battery Installation: 手順 1、 3の画像 3
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. Nokia 3120 Speaker Replacement: 手順 2、 1の画像 1
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
  3. Nokia 3120 Speaker Replacement, Face Plate: 手順 3、 3の画像 1 Nokia 3120 Speaker Replacement, Face Plate: 手順 3、 3の画像 2 Nokia 3120 Speaker Replacement, Face Plate: 手順 3、 3の画像 3
    • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
  4. Nokia 3120 Speaker Replacement, Speaker: 手順 4、 2の画像 1 Nokia 3120 Speaker Replacement, Speaker: 手順 4、 2の画像 2
    • Once the cover plate has been removed, the existing keypad should be easily removed.
  5. Nokia 3120 Speaker Replacement: 手順 5、 2の画像 1 Nokia 3120 Speaker Replacement: 手順 5、 2の画像 2
    • Once the keypad has been removed, unscrew the 6 exposed screws on the front of the phone.
  6. Nokia 3120 Speaker Replacement: 手順 6、 1の画像 1
    • Once all the screws have been removed, the front part of the phone should be removable from the rest of the phone.
  7. Nokia 3120 Speaker Replacement: 手順 7、 1の画像 1
    • To remove the speaker from the phone, take a pencil or sharp object and poke the speaker free from the removed front part of the phone.
    • To install a new speaker, simply place a new speaker in the same location and put the phone back together.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Pierre Tong
メンバー登録日: 03/11/13
92 ポイント
4のガイドは作成済み
チーム
Clemson, Team 13-2, Benson Spring 2013 Clemson, Team 13-2, Benson Spring 2013人のメンバー
CLEM-BENSON-S13S13G2
3 メンバー
14のガイドは作成済み
0 Guide Comments
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 17
今までの合計 1,256
