メインコンテンツにスキップ
Nintendo 3DS XL Touchscreen Replacement
Charlene Donlon
Charlene Donlon とその他 6 人の作成者
最終更新日: August 19, 2024
1 - 3 時間
中レベル
In order to reach the touchscreen of the Nintendo 3DS XL you will need to first remove the motherboard and accompanying parts. This guide will help you replace your touchscreen in no time!
必要な工具と部品
パーツ
ツール
もっと見る
  1. Nintendo 3DS XL Touchscreen Replacement, Battery: 手順 1、 2の画像 1 Nintendo 3DS XL Touchscreen Replacement, Battery: 手順 1、 2の画像 2
    • Loosen the two #00 Phillips 4.2 mm-length screws located at the top of the back cover.
    • The screws have locking washers that prevent the screws from falling off of the back cover. Leave these locking washers on the screws; it is not necessary to remove the washers for this repair guide.
  2. Nintendo 3DS XL Touchscreen Replacement: 手順 2、 2の画像 1 Nintendo 3DS XL Touchscreen Replacement: 手順 2、 2の画像 2
    • Hold the device so that the cover is facing up.
    • Using a plastic opening tool, pry off the cover starting at the top right corner.
    • Hold the edge of the cover to ensure it does not reattach.
    • Look for the small section below the stylus compartment. Pry off the cover at that point if it is still attached.
    • Take off the cover of the device and set it aside.
  3. Nintendo 3DS XL Touchscreen Replacement: 手順 3、 3の画像 1 Nintendo 3DS XL Touchscreen Replacement: 手順 3、 3の画像 2 Nintendo 3DS XL Touchscreen Replacement: 手順 3、 3の画像 3
    • Insert the plastic opening tool into the opening located on the right side of the battery.
    • Pry off the battery from the lower casing.
    • Lift the battery out of the case and set aside.
  4. Nintendo 3DS XL Touchscreen Replacement, Circle Pad Joystick: 手順 4、 2の画像 1 Nintendo 3DS XL Touchscreen Replacement, Circle Pad Joystick: 手順 4、 2の画像 2
    この手順で使用する道具:
    • Using tweezers pull out the rubber bumpers that are located at the top of the device on either side of the game cartridge compartment.
  5. Nintendo 3DS XL Touchscreen Replacement: 手順 5、 2の画像 1 Nintendo 3DS XL Touchscreen Replacement: 手順 5、 2の画像 2
    • Remove the six 6.2 mm screws using a Phillips #00 screwdriver
  6. Nintendo 3DS XL Touchscreen Replacement: 手順 6、 1の画像 1
    • Remove the 2.3 mm screw located above the game cartridge slot with a Phillips #00 screwdriver.
  7. Nintendo 3DS XL Touchscreen Replacement: 手順 7、 3の画像 1 Nintendo 3DS XL Touchscreen Replacement: 手順 7、 3の画像 2 Nintendo 3DS XL Touchscreen Replacement: 手順 7、 3の画像 3
    • Make sure the SD card has been removed. With a plastic opening tool pry off the lower case starting at the bottom edge and working around the perimeter.
    • Two ribbon cables connect the case to the circuit board. Be careful to not pull the case too hard and rip the ribbon cables.
  8. Nintendo 3DS XL Touchscreen Replacement: 手順 8、 3の画像 1 Nintendo 3DS XL Touchscreen Replacement: 手順 8、 3の画像 2 Nintendo 3DS XL Touchscreen Replacement: 手順 8、 3の画像 3
    • Remove the ribbon cables located underneath the left and right bumpers by prying up the base of the cables with a plastic opening tool.
    • Completely remove the lower case from the rest of the device and set aside.
  9. Nintendo 3DS XL Touchscreen Replacement: 手順 9、 2の画像 1 Nintendo 3DS XL Touchscreen Replacement: 手順 9、 2の画像 2
    • Position the device such that the game cartridge slot is located at the top.
    • Locate the circle pad on the right side of the device.
    • Remove the two 7.5 mm screws on the upper left and the bottom right corners.
  10. Nintendo 3DS XL Touchscreen Replacement: 手順 10、 2の画像 1 Nintendo 3DS XL Touchscreen Replacement: 手順 10、 2の画像 2
    • Using a plastic opening tool pop off the circle pad joystick.
    • Do not use excessive force with the plastic opening tool. There is a ribbon attaching the circle pad joystick to the motherboard that will remain attached.
    • There is a loose washer located in between the circle pad joystick and the circle pad. Use caution and do not lose this piece.
  11. Nintendo 3DS XL Touchscreen Replacement: 手順 11、 2の画像 1 Nintendo 3DS XL Touchscreen Replacement: 手順 11、 2の画像 2
    • Using the flat head side of the spudger carefully lift up the retaining flap that attaches the circle pad ribbon to the motherboard.
    • Remove the ribbon and circle pad joystick.
  12. Nintendo 3DS XL Touchscreen Replacement, IR Board: 手順 12、 2の画像 1 Nintendo 3DS XL Touchscreen Replacement, IR Board: 手順 12、 2の画像 2
    • Locate the IR board located on the upper right side of the motherboard.
    • The IR board is installed upside-down in these photos by mistake. Installing it this way will result in your DS failing to start. Note the orientation of your IR board before you remove it, and reinstall it the same way.
    • Remove the IR board with a plastic opening tool by inserting the tool below the IR board and gently prying up.
  13. Nintendo 3DS XL Touchscreen Replacement, Motherboard: 手順 13、 2の画像 1 Nintendo 3DS XL Touchscreen Replacement, Motherboard: 手順 13、 2の画像 2
    • Using a plastic opening tool, pry off the Wi-Fi board.
    • The Wi-Fi board will still be connected by a wire and it is not necessary to completely remove it for this step. Simply place it out of the way for this step.
  14. Nintendo 3DS XL Touchscreen Replacement: 手順 14、 2の画像 1 Nintendo 3DS XL Touchscreen Replacement: 手順 14、 2の画像 2
    この手順で使用する道具:
    • Locate the volume switch on the right side of the motherboard next to the circle pad joystick.
    • Using tweezers, carefully remove the volume board from the casing. It will still be attached to the motherboard by a ribbon cable.
  15. Nintendo 3DS XL Touchscreen Replacement: 手順 15、 1の画像 1
    • Using the flat head side of the spudger carefully lift up the flap that attaches the volume board ribbon to the motherboard.
    • Remove the volume board and set aside.
  16. Nintendo 3DS XL Touchscreen Replacement: 手順 16、 2の画像 1 Nintendo 3DS XL Touchscreen Replacement: 手順 16、 2の画像 2
    • Remove the black plastic pieces from the lower left and right hand corners with either your fingers or tweezers.
    • You can also remove these pieces easily by carefully lifting up the 3DS and holding it upside-down. They normally fall right out, but don't lose them!
  17. Nintendo 3DS XL Touchscreen Replacement: 手順 17、 3の画像 1 Nintendo 3DS XL Touchscreen Replacement: 手順 17、 3の画像 2 Nintendo 3DS XL Touchscreen Replacement: 手順 17、 3の画像 3
    • Using the flat head side of the spudger carefully lift up the flap that attaches the two smaller ribbons to the motherboard.
    • These flaps are located on the top right and bottom right side of the motherboard.
    • Remove the ribbons from the flap.
  18. Nintendo 3DS XL Touchscreen Replacement: 手順 18、 3の画像 1 Nintendo 3DS XL Touchscreen Replacement: 手順 18、 3の画像 2 Nintendo 3DS XL Touchscreen Replacement: 手順 18、 3の画像 3
    • Using the flat head side of the spudger carefully lift up the flaps that attach the wider ribbons to the motherboard.
    • For the wider ribbons make sure to lift the flaps from the white side.
    • Remove the ribbons from the opened flaps.
  19. Nintendo 3DS XL Touchscreen Replacement: 手順 19、 2の画像 1 Nintendo 3DS XL Touchscreen Replacement: 手順 19、 2の画像 2
    • Using the flat head side of the spudger carefully lift up the flap that attaches the ribbon to the motherboard.
    • For this flap lift from the black side.
    • Remove the ribbon from the flap.
    • Reassembly: This wide ribbon is the one with the BLACK STRIPE and goes on the upper (visible) side of the motherboard during reassembly.
  20. Nintendo 3DS XL Touchscreen Replacement: 手順 20、 2の画像 1 Nintendo 3DS XL Touchscreen Replacement: 手順 20、 2の画像 2
    • Remove ten 3.0 mm screws that are located around the face of the motherboard.
  21. Nintendo 3DS XL Touchscreen Replacement: 手順 21、 2の画像 1 Nintendo 3DS XL Touchscreen Replacement: 手順 21、 2の画像 2
    • The motherboard will still be attached at the top right hand corner so do not completely detach it at this point.
    • Carefully lift the board straight up just enough to clear the two plastic mounts located near the top corners of the cartridge slot.
    • Gently flip the motherboard over the top side.
  22. Nintendo 3DS XL Touchscreen Replacement: 手順 22、 2の画像 1 Nintendo 3DS XL Touchscreen Replacement: 手順 22、 2の画像 2
    • Using the flat head side of the spudger carefully lift up the flap that attaches the wider ribbon on the upper right side to the motherboard.
    • Make sure to lift the flap from the white side.
    • Remove the ribbon from the opened flap.
    • Set the motherboard aside.
  23. Nintendo 3DS XL Touchscreen Replacement, Touchscreen: 手順 23、 2の画像 1 Nintendo 3DS XL Touchscreen Replacement, Touchscreen: 手順 23、 2の画像 2
    • Open the device's hinge.
    • Gently press upward on the touchscreen until it separates from the casing.
    • If you are replacing the touchscreen assembly (touch digitizer & display), this is the final step. Continue to the next step if you are replacing the display separately from the touch digitizer.
  24. Nintendo 3DS XL Touchscreen Replacement, Separate the touchscreen: 手順 24、 2の画像 1 Nintendo 3DS XL Touchscreen Replacement, Separate the touchscreen: 手順 24、 2の画像 2
    • Starting at the bottom right corner, insert the flat end of a spudger between the touch digitizer and LCD frame and gently pry the touchscreen off the LCD.
    • Do not run the spudger down the side of the display assembly to loosen the touch digitizer. The two components of the display assembly are held together by a fairly weak adhesive tape, and running the spudger between the two could tangle or damage the tape.
    • Insert the spudger into the top right corner between the two pieces and pry the touch digitizer off the LCD frame.
  25. Nintendo 3DS XL Touchscreen Replacement: 手順 25、 2の画像 1 Nintendo 3DS XL Touchscreen Replacement: 手順 25、 2の画像 2
    • Repeat the above procedure for the remaining two corners to pry the touch digitizer off the LCD frame.
  26. Nintendo 3DS XL Touchscreen Replacement: 手順 26、 1の画像 1
    この手順で使用する道具:
    Tesa 61395 Tape
    $2.99
    • Gently lift the touch digitizer up to completely separate it from the lower LCD.
    • If your replacement touch digitizer does not include new adhesive, use thin, double-sided tape instead
終わりに
65 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Charlene Donlon
メンバー登録日: 04/08/14
10,610 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 9-13, Regan Spring 2014 Cal Poly, Team 9-13, Regan Spring 2014人のメンバー
CPSU-REGAN-S14S9G13
5 メンバー
44のガイドは作成済み
24 件のコメント
what if you need to replace the screen on the top housing? what is it called.
kerriereed - 返信
Is the bottom LCD screen of the Nintendo 3ds xl, the same as the one in the NEW Nintendo 3ds xl?
Looking for what part to buy.
markknobel - 返信
Bit old, but did you figure out the answer which to buy?
White -
Very detailed and easy to use step by step thanks. However, after reassembly after I switch the power button on it starts and then a flash and it trips out? Obviously a fault somewhere but not sure where to start.? Any thoughts appreciated.
Pete Mason - 返信
That's to do with a part this tutorial skips: you need to put some insulation between the new screen and the motherboard. That's what that orange film is on the back of the screen in the photos. When replacing, you can easily (carefully) remove that film and stick it onto the back of the new screen, no problem. Or you can put some other sort of adhesive to create some insulation between the screen and motherboard. Hope this helps.
Albert Wiltfong -
コメントを追加
統計データ:
過去 24時間: 27
過去 7 日: 238
過去 30 日: 864
今までの合計 101,005
