メインコンテンツにスキップ
Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement
Dylan Cooper Dalrymple
Dylan Cooper Dalrymple とその他 5 人の作成者
最終更新日: December 2, 2015
3分
中レベル
This spring piston mechanism acts as the primary form of energy storage for your blaster to fire darts. When the blaster is cocked, the air-tight piston mechanism is pulled back and the large spring is compressed, holding in potential energy. Once the blaster is triggered, the energy from the spring pushes the piston forward towards the front of the blaster. Because the piston is air-tight against the walls of the chamber, it pushes all of the air out towards the opening in the front. As this air exits the chamber, it then pushes the dart out of the barrel. If any issues exist with this device, it is usually with the chamber being air-tight. If any air is allowed to exit otherwise, it greatly reduces the effectiveness of the blaster.
必要な工具と部品
ツール
  1. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement, Outer Shell: 手順 1、 2の画像 1 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement, Outer Shell: 手順 1、 2の画像 2
    • Lay the Nerf Strongarm on its side, left side facing up.
  2. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 手順 2、 2の画像 1 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 手順 2、 2の画像 2
    • Locate the 12 Philips head screws and remove them: Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
  3. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 手順 3、 1の画像 1
    • Before removing the cover, make sure to first remove the cover for the cocking mechanism. The top half is freely removable.
    • The other half of the cocking mechanism is connected with a spring which may slide off the blaster. Be advised this is normal but worth watching to avoid damaging the spring.
  4. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 手順 4、 1の画像 1
    • At this time, remove the blaster cover to reveal its internals.
    • If the blaster is resting on its side, the barrel may shift slightly as it is leaning on itself (seen in the image). This is normal but should be handled with care to keep the blaster together.
  5. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 手順 5、 1の画像 1
    • Once the screws have been removed, lift the top half of the gun off.
    • Notice, the gray colored piece must be removed first in order for the larger half to be removed.
    • Take care and try not to lose any smaller pieces as you open it up.
    • Locking tab for attachments.
  6. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement, Spring Piston Chamber: 手順 6、 2の画像 1 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement, Spring Piston Chamber: 手順 6、 2の画像 2
    • First, remove the outer parts of the blaster, starting with the top part of the cocking mechanism. Then remove the full cover itself.
  7. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 手順 7、 2の画像 1 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 手順 7、 2の画像 2
    • Remove the barrel and the front part of the blaster. The components should simply slide off.
  8. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 手順 8、 1の画像 1
    • Remove the screw on the inside of the gun.
    • Screw specifications: Philips head, Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
  9. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 手順 9、 3の画像 1 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 手順 9、 3の画像 2 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 手順 9、 3の画像 3
    • Remove the trigger, the cocking holdback, and the air compressor chamber
  10. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 手順 10、 1の画像 1
    • Remove the spring holding the air compressor together.
  11. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 手順 11、 1の画像 1
    • Remove the spring air compressor component.
  12. Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 手順 12、 3の画像 1 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 手順 12、 3の画像 2 Nerf N-Strike Elite Strongarm Spring Piston Chamber Replacement: 手順 12、 3の画像 3
    • This is the spring that controls the air compressor. If it is damaged you have found your problem. Replace this spring and the blaster should work.
終わりに
7 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
メンバー登録日: 01/15/15
741 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 5-4, Blackwell Fall 2015 USF Tampa, Team 5-4, Blackwell Fall 2015人のメンバー
USFT-BLACKWELL-F15S5G4
4 メンバー
13のガイドは作成済み
4 件のコメント
mi nerf strongarm no dispara los dardos con la misma potencia que cuando la utilice por primera vez, dispara los dardos demasiado suave
juanestebanlopezcastrillon - 返信
Maybe the problem is the dards.
Álvaro Sousa PT -
My nerf elite disruptor's drum some times working but sometimes notworkin
Skm - 返信
what is the size of the spring?
JoseRafael - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 25
過去 30 日: 87
今までの合計 32,683
