メインコンテンツにスキップ
Nerf N-Strike Deploy CS-6 Dart Tooth Replacement
Alec Hernandez
Alec Hernandez とその他 3 人の作成者
最終更新日: October 22, 2018
35分
中レベル
One of the lesser known pieces to the Nerf N-Strike Deploy CS-6 device is the dart tooth. Other than the internal spring, the dart tooth is what helps aid in firing the darts. If there is any incorrect adjustments or damage to the dart tooth, the device will not function properly unless the pieces are properly replaced. This guide will aid you in ensuring the dart tooth function properly for the device.
必要な工具と部品
ツール
  1. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement, Dart Tooth: 手順 1、 1の画像 1
    • Before releasing the device in Stealth mode, take out hidden screws as shown
    • Extend the device in Stealth Mode by pressing the button found on the handle.
  2. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 2、 3の画像 1 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 2、 3の画像 2 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 2、 3の画像 3
    • Take out the screws from the pump.
    • Proceed to take out the other screws from the device to take off the cover.
    • For the pump, the screw's length extends out to 1.9 cm. The majority size of the screws extend out to 1.3 cm.
  3. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 3、 2の画像 1 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 3、 2の画像 2
    • Once the screws are out, you are able to take the cover piece off.
    • Proceed to remove the screws
    • Taking off those screws are vital in replacing the dart tooth.
  4. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 4、 1の画像 1
    • Carefully place cover piece above the device.
  5. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 5、 1の画像 1
    • Unscrew as shown to aid in the replacement.
  6. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 6、 1の画像 1
    • To take out the dart tooth, push the spring to the left.
    • The dart tooth should pop out with ease.
  7. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 7、 1の画像 1
    • Once pulled away from the device, take off the orange piece connected to the darth tooth
    • The piece can be identified with the spring.
  8. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 8、 1の画像 1
    • You should now be able to pull apart the dart tooth from the device.
    • The piece that has been pulled away will have a type of lubrication. If this piece requires replacement, it will slide on with ease.
  9. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 9、 1の画像 1
    • Make any adjustment to the dart tooth as seen. May be pulled either up or down.
    • Place in the replacing piece in order to fix the darth tooth
  10. Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 10、 3の画像 1 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 10、 3の画像 2 Nerf N-Strike Deploy CS-6 Dart Tooth Replacement: 手順 10、 3の画像 3
    • Place back on the orange piece with the spring to its original spot on the dart tooth.
    • While setting in the dart tooth back into place, the small spring on the yellow piece must be placed in its compartment as shown.
    • Place back cover pieces in order to secure the screws back into place.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Alec Hernandez
メンバー登録日: 09/28/16
126 ポイント
2のガイドは作成済み
チーム
Eastern Washington University, Team 2-5, Mathisen Fall 2016 Eastern Washington University, Team 2-5, Mathisen Fall 2016人のメンバー
EWU-MATHISEN-F16S2G5
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 3,124
