メインコンテンツにスキップ
Mr. Coffee BVMC-SJX33GT Valve Replacement
Mackenzie Aiken
Mackenzie Aiken とその他 人の作成者
最終更新日: June 23, 2015
10 - 15 分
簡単
Coffee grinds can often get stuck in the valve that controls the flow of water from the reservoir to the heating element. This guide will help you remove the valve if it needs cleaning or replace it if it is broken.
Make sure your coffee maker is unplugged and empty of all water before attempting to make any repairs.
必要な工具と部品
ツール
もっと見る
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. Mr. Coffee BVMC-SJX33GT Valve Replacement, Base: 手順 1、 1の画像 1
    • Turn your coffee maker over so that the base is facing up.
  2. Mr. Coffee BVMC-SJX33GT Valve Replacement: 手順 2、 2の画像 1 Mr. Coffee BVMC-SJX33GT Valve Replacement: 手順 2、 2の画像 2
    • Locate the seven 13.5mm screws securing the base to the coffee maker.
    • Unscrew the screws using a #2 Phillips head screwdriver.
    • Use a screwdriver with a magnetic tip to more easily remove the three screws in the back and two in the middle.
  3. Mr. Coffee BVMC-SJX33GT Valve Replacement, security screws: 手順 3、 1の画像 1
    • Also the front two screws are safety screws: they have a 6 sided star shape with a raised dimple in the center to prevent homebodies from casually opening the machine. (probably from the Sunbeam’s (owns Mr. Coffee) legal dept.) Anyway you will need a security bit to remove the screws and not a phillips screw driver.
  4. Mr. Coffee BVMC-SJX33GT Valve Replacement: 手順 4、 1の画像 1
    • Lift base to remove.
    • If the base sticks along one edge, do not pull at an angle. Gently tug straight up while sliding a finger along the edge in order to pop the clips.
  5. Mr. Coffee BVMC-SJX33GT Valve Replacement, Rubber Hose: 手順 5、 3の画像 1 Mr. Coffee BVMC-SJX33GT Valve Replacement, Rubber Hose: 手順 5、 3の画像 2 Mr. Coffee BVMC-SJX33GT Valve Replacement, Rubber Hose: 手順 5、 3の画像 3
    • Locate the metal clamps.
    • Using a pair of pliers or your fingers, slide clamps away from tube opening.
    • All following steps regarding the rubber hoses should be completed for both hoses.
  6. Mr. Coffee BVMC-SJX33GT Valve Replacement: 手順 6、 3の画像 1 Mr. Coffee BVMC-SJX33GT Valve Replacement: 手順 6、 3の画像 2 Mr. Coffee BVMC-SJX33GT Valve Replacement: 手順 6、 3の画像 3
    • Using a plastic opening tool, loosen rubber hose from metal tubing.
    • Once loosened, grip the hose and pull it from the metal tubing.
  7. Mr. Coffee BVMC-SJX33GT Valve Replacement: 手順 7、 2の画像 1 Mr. Coffee BVMC-SJX33GT Valve Replacement: 手順 7、 2の画像 2
    • Slide metal clamps off hoses.
  8. Mr. Coffee BVMC-SJX33GT Valve Replacement: 手順 8、 2の画像 1 Mr. Coffee BVMC-SJX33GT Valve Replacement: 手順 8、 2の画像 2
    • Locate the other set of metal clamps.
    • Using needle nose pliers or your fingers remove these clamps by pinching the clamps and sliding them up the tubes.
  9. Mr. Coffee BVMC-SJX33GT Valve Replacement: 手順 9、 2の画像 1 Mr. Coffee BVMC-SJX33GT Valve Replacement: 手順 9、 2の画像 2
    • Grip the hoses and pull them straight up and out.
  10. Mr. Coffee BVMC-SJX33GT Valve Replacement, Valve: 手順 10、 2の画像 1 Mr. Coffee BVMC-SJX33GT Valve Replacement, Valve: 手順 10、 2の画像 2
    • After pulling the second tube out, locate the bulging part of the hose that indicates the valve's placement.
  11. Mr. Coffee BVMC-SJX33GT Valve Replacement: 手順 11、 3の画像 1 Mr. Coffee BVMC-SJX33GT Valve Replacement: 手順 11、 3の画像 2 Mr. Coffee BVMC-SJX33GT Valve Replacement: 手順 11、 3の画像 3
    • Grip the tube and push the valve out the end of the hose.
    • Remember the direction of the valve when you pull it out because this valve is one way. If you insert it or reinsert it the wrong way, water will not flow through the coffee maker.
終わりに
15 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Mackenzie Aiken
メンバー登録日: 01/27/15
1,500 ポイント
6のガイドは作成済み
チーム
San Diego State, Team 1-4, Sheppard Winter 2015 San Diego State, Team 1-4, Sheppard Winter 2015人のメンバー
SDSU-SHEPPARD-W15S1G4
2 メンバー
6のガイドは作成済み
21 件のコメント
Thank you. Beautiful in it's clarity and simplicity. The attention to detail with specific regard to the size of bolts and tools needed moved me. Too much? Maybe a little. Thank you anyway.
jdwolf1282 - 返信
Thank you. Very well done. Do you know if I can buy a replacement valve?
Scott - 返信
Unfortunately no. Because a lot of things are built with planned obsolescence in mind, it's very difficult to find parts. I would check thrift stores for same brand cheap coffee makers that might have similar equipment.
Mackenzie Aiken -
I have a similar model and the valve sticks at odd times...it brews half the pot and steams the rest of the water. I have cleaned, drilled the hole slightly larger that the ball seals in...with no solution! Will it it thermally pump water without the ball in the valve? Thanks!
elronhubbard - 返信
Well firstly make sure the valve is pointing the right direction in the rubber tubing. As for your question about pumping water, that I can't answer. Try soaking the valve in alcohol then warm soapy water, there may be residue from the grinds on the ball causing it to stick.
Your best course of action might be to go to a thrift store and look for a similar model by Mr. Coffee and simply replace the valve. Drilling the hole initially might have thwarted additional attempts to make this valve work.
Mackenzie Aiken -
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 45
過去 30 日: 152
今までの合計 65,620
