メインコンテンツにスキップ
Mr. Coffee BVMC-SJX33GT O-Rings Replacement
Mackenzie Aiken
Mackenzie Aiken とその他 人の作成者
最終更新日: June 23, 2015
20 - 25 分
中レベル
There are two O-rings in the Mr. Coffee BVMC-SJX33GT; If your coffee maker is leaking, the O-rings may potentially be damaged in some way and in need of replacement.
Make sure your coffee maker is unplugged and empty of all water before attempting to make any repairs.
必要な工具と部品
ツール
もっと見る
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Base: 手順 1、 1の画像 1
    • Turn your coffee maker over so that the base is facing up.
  2. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 2、 2の画像 1 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 2、 2の画像 2
    • Locate the seven 13.5mm screws securing the base to the coffee maker.
    • Unscrew the screws using a #2 Phillips head screwdriver.
    • Use a screwdriver with a magnetic tip to more easily remove the three screws in the back and two in the middle.
  3. Mr. Coffee BVMC-SJX33GT O-Rings Replacement, security screws: 手順 3、 1の画像 1
    • Also the front two screws are safety screws: they have a 6 sided star shape with a raised dimple in the center to prevent homebodies from casually opening the machine. (probably from the Sunbeam’s (owns Mr. Coffee) legal dept.) Anyway you will need a security bit to remove the screws and not a phillips screw driver.
  4. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 4、 1の画像 1
    • Lift base to remove.
    • If the base sticks along one edge, do not pull at an angle. Gently tug straight up while sliding a finger along the edge in order to pop the clips.
  5. Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Rubber Hose: 手順 5、 3の画像 1 Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Rubber Hose: 手順 5、 3の画像 2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Rubber Hose: 手順 5、 3の画像 3
    • Locate the metal clamps.
    • Using a pair of pliers or your fingers, slide clamps away from tube opening.
    • All following steps regarding the rubber hoses should be completed for both hoses.
  6. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 6、 3の画像 1 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 6、 3の画像 2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 6、 3の画像 3
    • Using a plastic opening tool, loosen rubber hose from metal tubing.
    • Once loosened, grip the hose and pull it from the metal tubing.
  7. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 7、 2の画像 1 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 7、 2の画像 2
    • Slide metal clamps off hoses.
  8. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 8、 2の画像 1 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 8、 2の画像 2
    • Locate the other set of metal clamps.
    • Using needle nose pliers or your fingers remove these clamps by pinching the clamps and sliding them up the tubes.
  9. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 9、 2の画像 1 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 9、 2の画像 2
    • Grip the hoses and pull them straight up and out.
  10. Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Heating Plate: 手順 10、 3の画像 1 Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Heating Plate: 手順 10、 3の画像 2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement, Heating Plate: 手順 10、 3の画像 3
    • Locate the two 17mm screws securing the bracing bar.
    • Unscrew the screws with a #2 Phillip's head screwdriver and remove the bracing bar
  11. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 11、 2の画像 1 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 11、 2の画像 2
    • Using a finger to keep the heating plate in place, grip the metal tubing and gently pull it away from the plate.
    • Set the metal tubing aside.
  12. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 12、 2の画像 1 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 12、 2の画像 2
    • Push the heating plate up from below and remove.
  13. Mr. Coffee BVMC-SJX33GT O-Rings Replacement, O-Rings: 手順 13、 2の画像 1 Mr. Coffee BVMC-SJX33GT O-Rings Replacement, O-Rings: 手順 13、 2の画像 2
    • Locate the five 11.5mm screws securing the plastic ring to the coffee maker.
    • Unscrew the screws using a #2 Phillip's head screwdriver.
  14. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 14、 3の画像 1 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 14、 3の画像 2 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 14、 3の画像 3
    • Using a plastic opening tool, pry the first o-ring out of the plastic ring.
    • If you happen to mix up the o-rings, note that this o-ring is thicker than the second.
  15. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 15、 2の画像 1 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 15、 2の画像 2
    • Gripping the plastic ring, pull it free from the coffee maker.
    • Flip the plastic ring over.
  16. Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 16、 2の画像 1 Mr. Coffee BVMC-SJX33GT O-Rings Replacement: 手順 16、 2の画像 2
    • Using your fingers, pry the other o-ring free from the plastic ring.
    • If you happen to mix up the o-rings, note that this o-ring is thinner than the first.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Mackenzie Aiken
メンバー登録日: 01/27/15
1,500 ポイント
6のガイドは作成済み
チーム
San Diego State, Team 1-4, Sheppard Winter 2015 San Diego State, Team 1-4, Sheppard Winter 2015人のメンバー
SDSU-SHEPPARD-W15S1G4
2 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 16
今までの合計 2,488
