Motorola i886 Screen Replacement
はじめに
手順 1 に進むThis guide shows how to open the Motorola i866 and replace the screen.
必要な工具と部品
Undo the headphone jack and USB port cover with your fingertip. Place your middle finger in the indent on the upper left side of the back of the phone.
Locate battery and use your index finger to grasp the upper left side of the battery and pull back to remove. Set battery aside.
Locate and use your thumb to slide the SIM card to the right until it is removed and set it aside.
Remove eight black .4 centimeter screws on the top, bottom, and sides of the phone with a T5 Torx screwdriver by inserting it into the screws and turning it to the left. Set screws aside.
Loosen four fastener pieces on the side and bottom with a plastic opening tool to pry them backwards.
Insert the plastic opening tool between the loosened casing and the rest of the phone and pry the two pieces apart to remove the casing.
Locate and grip the black, white, and blue keyboard layer with your fingernail, lift up to remove it.
Disconnect piece connecting the two parts of the phone by using your index finger and thumb to pry them apart, you will hear a soft click.
Set aside the part of the phone without the strip.
Remove the loose volume, speaker, and camera buttons.
Remove four silver .2 centimeter screws above and below the gold and black strip with a T4 Torx screwdriver.
Separate the two parts of the phone by holding one side in each hand and pulling them apart. Set the part that held the slide-out keyboard aside.
この手順で使用する道具:Tweezers$4.99
Remove six silver .3 centimeter screws from the top, bottom, and sides with the T4 Torx screwdriver.
Peel back the yellow tape on the side of the screen using tweezers or your fingernails. Lift away screen and board.
Lift the yellow strip away from the back of the screen by gently gripping with tweezers and detaching the two, black, square, contact points.
Pry the bar connecting the screen and circuit board by prying it gently upwards with tweezers to detach, separate, and remove the screen.
