Insert the spudger between the gray and black plates of the screen casing.
Using a twist and pry motion work your way around the phone slowly prying the two plates apart.
Note: this part of the phone is glued and will require re-gluing to return the phone to its original state.
If you look at the side of the now exposed screen there should be a metal casing held onto the phone by two tabs.
Insert the spudger underneath one of the corners of the metal and bend it out enough to slip it over the tabs.
This metal is reasonably resistant to bending and will likely require a good deal of force to get it off the phone.
