メインコンテンツにスキップ
Motorola V325 Screen and External Display Disassembly
Danny Breslow
Danny Breslow とその他 5 人の作成者
最終更新日: February 19, 2016
15 - 20 分
中レベル
The guide will show you how to safely remove the screen and external display from your phone.
必要な工具と部品
  1. Motorola V325 Screen and External Display Disassembly, External Casing: 手順 1、 3の画像 1 Motorola V325 Screen and External Display Disassembly, External Casing: 手順 1、 3の画像 2 Motorola V325 Screen and External Display Disassembly, External Casing: 手順 1、 3の画像 3
    • Remove the rearmost panel by pushing down on the silver button, then simultaneously pulling downward on the panel.
    • Lift the panel off of the phone.
  2. Motorola V325 Screen and External Display Disassembly: 手順 2、 3の画像 1 Motorola V325 Screen and External Display Disassembly: 手順 2、 3の画像 2 Motorola V325 Screen and External Display Disassembly: 手順 2、 3の画像 3
    • Using your thumbnail or a thin flat head screwdriver, peel back the screen protector on the inside of the phone: It is only held on by glue but may take a good amount of force to be removed.
  3. Motorola V325 Screen and External Display Disassembly: 手順 3、 2の画像 1 Motorola V325 Screen and External Display Disassembly: 手順 3、 2の画像 2
    • Unscrew the four screws using the T6 Torx Screwdriver.
  4. Motorola V325 Screen and External Display Disassembly: 手順 4、 3の画像 1 Motorola V325 Screen and External Display Disassembly: 手順 4、 3の画像 2 Motorola V325 Screen and External Display Disassembly: 手順 4、 3の画像 3
    • Peel back the screen protector frame. Close phone at the hinge, then pull off the front outer casing.
  5. Motorola V325 Screen and External Display Disassembly, Motorola V325 Screen and External Display Disassembly: 手順 5、 2の画像 1 Motorola V325 Screen and External Display Disassembly, Motorola V325 Screen and External Display Disassembly: 手順 5、 2の画像 2
    • After removing the external casing, there are no more screws holding on the gray metal plate. Carefully separate the gray plate from the rest of the phone by simply lifting it off.
  6. Motorola V325 Screen and External Display Disassembly: 手順 6、 3の画像 1 Motorola V325 Screen and External Display Disassembly: 手順 6、 3の画像 2 Motorola V325 Screen and External Display Disassembly: 手順 6、 3の画像 3
    • Next separate the screen from the phone, pulling it away slowly as it will still be attached by a yellow ribbon.
    • A yellow ribbon attaches to the area boxed in blue. Unclip the yellow ribbon from the circuit board using your fingers.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Danny Breslow
メンバー登録日: 01/14/10
19 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 4-15, Forte Winter 2010 Cal Poly, Team 4-15, Forte Winter 2010人のメンバー
CPSU-FORTE-W10S4G15
5 メンバー
8のガイドは作成済み
1ガイドコメント
This was SO very helpful! I had dropped my V325 phone the other day and when I opened it, the screen was dark :( However, it still dialed and received calls so I was HOPING that a connection to the screen was the issue. Following this guide, I was able to get to the back of the display and sure enough, a connection was out of place. Put it back together and everything is working great!
Thanks so much!
Bob
Bob - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 12
過去 30 日: 12
今までの合計 2,873
