メインコンテンツにスキップ
Motorola Droid X Motherboard Replacement
Sam Johnston
Sam Johnston とその他 9 人の作成者
最終更新日: May 7, 2024
30 - 45 分
難しい
If no other troubleshooting tips help, it may be time to install a new motherboard. This installation guide will walk the reader through the steps required in replacing the motherboard.
必要な工具と部品
ツール
もっと見る
  1. Motorola Droid X Motherboard Replacement, Battery: 手順 1、 2の画像 1 Motorola Droid X Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • Locate the power button at the top of the phone. Depress power button for 2 seconds until a menu appears.
  2. Motorola Droid X Motherboard Replacement: 手順 2、 2の画像 1 Motorola Droid X Motherboard Replacement: 手順 2、 2の画像 2
    • Once the menu appears, select the "power off" option. Wait until the phone is completely off.
  3. Motorola Droid X Motherboard Replacement: 手順 3、 2の画像 1 Motorola Droid X Motherboard Replacement: 手順 3、 2の画像 2
    • Place thumb on the back cover, and push down towards the bottom of the device. Once the cover releases, pull it away from the phone and set it aside.
  4. Motorola Droid X Motherboard Replacement: 手順 4、 2の画像 1 Motorola Droid X Motherboard Replacement: 手順 4、 2の画像 2
    • Find the yellow pull tab located in the upper left corner. Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case.
  5. Motorola Droid X Motherboard Replacement: 手順 5、 1の画像 1
    • The battery has been successfully removed.
  6. Motorola Droid X Motherboard Replacement, Motorola Droid X Rear Housing: 手順 6、 1の画像 1
    • Remove the micro SD card from its connector.
  7. Motorola Droid X Motherboard Replacement: 手順 7、 3の画像 1 Motorola Droid X Motherboard Replacement: 手順 7、 3の画像 2 Motorola Droid X Motherboard Replacement: 手順 7、 3の画像 3
    • Locate the seam between the back case and the end cover on the top edge of the phone.
    • Use the plastic opening tool to detach the two clips by wedging the tool into the right side of the seam and moving right to left. Once the cover comes off set it aside
  8. Motorola Droid X Motherboard Replacement: 手順 8、 3の画像 1 Motorola Droid X Motherboard Replacement: 手順 8、 3の画像 2 Motorola Droid X Motherboard Replacement: 手順 8、 3の画像 3
    • Repeat step 2 on the bottom cover.
  9. Motorola Droid X Motherboard Replacement: 手順 9、 3の画像 1 Motorola Droid X Motherboard Replacement: 手順 9、 3の画像 2 Motorola Droid X Motherboard Replacement: 手順 9、 3の画像 3
    • Use a T5 Torx screwdriver to remove the screws in each corner of the phone.
    • The screws are very small so make sure not to lose them.
  10. Motorola Droid X Motherboard Replacement: 手順 10、 2の画像 1 Motorola Droid X Motherboard Replacement: 手順 10、 2の画像 2
    • Flip the phone over and locate the screw on the middle of the left side. Unscrew it using the T5 Torx screwdriver and set it aside.
  11. Motorola Droid X Motherboard Replacement: 手順 11、 2の画像 1 Motorola Droid X Motherboard Replacement: 手順 11、 2の画像 2
    • Identify the screw located in the bottom right corner of the battery case. Remove the screw with a T5 (or in some cases T6) torx screwdriver and set it aside.
  12. Motorola Droid X Motherboard Replacement: 手順 12、 2の画像 1 Motorola Droid X Motherboard Replacement: 手順 12、 2の画像 2
    • Locate the seam along the right edge of the phone. Use the prying tool to disconnect the two clips along the edge.
  13. Motorola Droid X Motherboard Replacement: 手順 13、 3の画像 1 Motorola Droid X Motherboard Replacement: 手順 13、 3の画像 2 Motorola Droid X Motherboard Replacement: 手順 13、 3の画像 3
    • Locate the two clips on the inside of the case and use the spudger tool to detach them from the case. To detach each clip, use the sharp end to press the small, black plastic in the center of the clip.
  14. Motorola Droid X Motherboard Replacement: 手順 14、 2の画像 1 Motorola Droid X Motherboard Replacement: 手順 14、 2の画像 2
    • After the clips are detached, remove the back case and set it aside.
  15. Motorola Droid X Motherboard Replacement, Motherboard: 手順 15、 1の画像 1
    • Remove the screws along both sides of the motherboard using a T3 Torx screwdriver. On some phones this may require a #1 Phillips Screw Driver.
  16. Motorola Droid X Motherboard Replacement: 手順 16、 2の画像 1 Motorola Droid X Motherboard Replacement: 手順 16、 2の画像 2
    この手順で使用する道具:
    • Carefully remove the white connecting wire from the motherboard using tweezers.
    • Use caution, this wire is delicate.
  17. Motorola Droid X Motherboard Replacement: 手順 17、 2の画像 1 Motorola Droid X Motherboard Replacement: 手順 17、 2の画像 2
    • Scrape away the electrical tape that covers the LCD and digitizer cable using the spudger tool or a fingernail.
  18. Motorola Droid X Motherboard Replacement: 手順 18、 1の画像 1
    • Use the spudger tool to pop the Digitizer cable off of the motherboard.
  19. Motorola Droid X Motherboard Replacement: 手順 19、 1の画像 1
    • Carefully flip the small white connector up and away from the motherboard.
  20. Motorola Droid X Motherboard Replacement: 手順 20、 1の画像 1
    • Gently pull the flat gold cable out from the connector.
  21. Motorola Droid X Motherboard Replacement: 手順 21、 1の画像 1
    • Carefully lift the motherboard and camera module up. Do not remove it from the phone!
  22. Motorola Droid X Motherboard Replacement: 手順 22、 1の画像 1
    • Using the spudger tool, pop the black cable connector off of the motherboard.
  23. Motorola Droid X Motherboard Replacement: 手順 23、 1の画像 1
    • It is to safe remove the motherboard from the phone.
終わりに
ある他の人がこのガイドを完成しました。
作成者
9人の作成者と共同で作成されました。
Sam Johnston
メンバー登録日: 10/03/12
576 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 18-40, Regan Fall 2012 Cal Poly, Team 18-40, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S18G40
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 11
今までの合計 3,854
