Motorola Droid Pro Screen Replacement
はじめに
手順 1 に進むBefore you begin, make sure you power down your device and work in a clean area. Also, wear a static band to prevent damage to your device.
Use your plastic opening tool to disconnect the motherboard/keyboard ribbon cable.
Unlock the screen's ribbon cable.
To remove the screen, you have to flip the phone over and let it fall out slowly into your hand. Be careful not to put any tension on the ribbon cable.
Then pull the screen away from the ribbon cable connector and it will slide out easily. Do not use excessive force.
4 の人々がこのガイドを完成させました。
