メインコンテンツにスキップ
Motorola Droid Pro Motherboard Replacement
Richard Bellizzi
Richard Bellizzi とその他 2 人の作成者
最終更新日: February 21, 2022
15分
中レベル
おすすめの学生による修理ガイド
Before you begin, make sure you power down your device and work in a clean area. Also, wear a static band to prevent damage to your device.
必要な工具と部品
パーツ
ツール
もっと見る
  1. Motorola Droid Pro Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Remove the back cover using the thumb tab located on the bottom of the phone.
  2. Motorola Droid Pro Motherboard Replacement: 手順 2、 2の画像 1 Motorola Droid Pro Motherboard Replacement: 手順 2、 2の画像 2
    • Remove the battery using the thumb tab.
  3. Motorola Droid Pro Motherboard Replacement, SD Card/SIM Card PCB Board: 手順 3、 2の画像 1 Motorola Droid Pro Motherboard Replacement, SD Card/SIM Card PCB Board: 手順 3、 2の画像 2
    • Using a T4 Torx driver, remove the eight 4 mm back panel screws.
  4. Motorola Droid Pro Motherboard Replacement: 手順 4、 3の画像 1 Motorola Droid Pro Motherboard Replacement: 手順 4、 3の画像 2 Motorola Droid Pro Motherboard Replacement: 手順 4、 3の画像 3
    • Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use extra force to unlock them.
    • Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
  5. Motorola Droid Pro Motherboard Replacement: 手順 5、 2の画像 1 Motorola Droid Pro Motherboard Replacement: 手順 5、 2の画像 2
    • Gently lift the SD & SIM card board (PCB) as shown.
    • There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
  6. Motorola Droid Pro Motherboard Replacement, Motherboard: 手順 6、 2の画像 1 Motorola Droid Pro Motherboard Replacement, Motherboard: 手順 6、 2の画像 2
    • Use your plastic opening tool to disconnect the motherboard/keyboard ribbon cable.
    • There are small tabs on the side of the connectors to wedge your tool under.
  7. Motorola Droid Pro Motherboard Replacement: 手順 7、 2の画像 1 Motorola Droid Pro Motherboard Replacement: 手順 7、 2の画像 2
    • Use your plastic opening tool to disconnect the two ribbon cables at the top of the phone.
  8. Motorola Droid Pro Motherboard Replacement: 手順 8、 2の画像 1 Motorola Droid Pro Motherboard Replacement: 手順 8、 2の画像 2
    • Disconnect the 2nd keyboard connector from the motherboard and remove it from its side holders.
    • This cable is fragile so be careful when disconnecting and moving it around.
  9. Motorola Droid Pro Motherboard Replacement: 手順 9、 1の画像 1
    • Use a T5 Torx Screwdriver to unscrew the 2mm screw.
  10. Motorola Droid Pro Motherboard Replacement: 手順 10、 3の画像 1 Motorola Droid Pro Motherboard Replacement: 手順 10、 3の画像 2 Motorola Droid Pro Motherboard Replacement: 手順 10、 3の画像 3
    • Remove the camera's rubber seal by pulling it off. It is not connected to anything.
  11. Motorola Droid Pro Motherboard Replacement: 手順 11、 2の画像 1 Motorola Droid Pro Motherboard Replacement: 手順 11、 2の画像 2
    • To remove the motherboard, pull it to the side. The camera that is connected to the motherboard does not pull straight up and out from its holder.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Richard Bellizzi
メンバー登録日: 10/28/15
352 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 1-6, Miles Fall 2015 UMass Dartmouth, Team 1-6, Miles Fall 2015人のメンバー
UMASSD-MILES-F15S1G6
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 331
