メインコンテンツにスキップ
Motorola Droid 4 SIM Card Replacement
Javier
Javier とその他 5 人の作成者
最終更新日: May 7, 2024
5分
とても簡単
コミュニティメンバーによる寄稿ガイド
The SIM card stores important information on your phone. You should handle it with care when you are using this guide.
You will need to remove several torx head screws. Make sure to use the correct type.
必要な工具と部品
  1. Motorola Droid 4 SIM Card Replacement, Removing Rear Panel: 手順 1、 3の画像 1 Motorola Droid 4 SIM Card Replacement, Removing Rear Panel: 手順 1、 3の画像 2 Motorola Droid 4 SIM Card Replacement, Removing Rear Panel: 手順 1、 3の画像 3
    • Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
    • Slide the cover down to remove.
  2. Motorola Droid 4 SIM Card Replacement, Lifting the SIM card cover: 手順 2、 3の画像 1 Motorola Droid 4 SIM Card Replacement, Lifting the SIM card cover: 手順 2、 3の画像 2 Motorola Droid 4 SIM Card Replacement, Lifting the SIM card cover: 手順 2、 3の画像 3
    この手順で使用する道具:
    • Using tweezers or your finger, lift the rubber SIM card cover to expose the card itself.
  3. Motorola Droid 4 SIM Card Replacement, Removing SIM card: 手順 3、 3の画像 1 Motorola Droid 4 SIM Card Replacement, Removing SIM card: 手順 3、 3の画像 2 Motorola Droid 4 SIM Card Replacement, Removing SIM card: 手順 3、 3の画像 3
    • While holding the cover open, use your finger to press and slide out the SIM card.
    • When reinserting the SIM card, make sure the SIM card is oriented in the correct direction, according to the illustration on the device, and that the metal contact area of the card is facing down.
  4. Motorola Droid 4 SIM Card Replacement, Insert new SIM card: 手順 4、 3の画像 1 Motorola Droid 4 SIM Card Replacement, Insert new SIM card: 手順 4、 3の画像 2 Motorola Droid 4 SIM Card Replacement, Insert new SIM card: 手順 4、 3の画像 3
    • Follow the same steps in the opposite order to install the new SIM card.
    • Make sure the SIM card is oriented in the correct direction, according to the illustration on the device, and that the metal contact area of the card is facing down.
ゴール
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Javier
メンバー登録日: 09/29/14
530 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 5-1, Mcgee Fall 2014 USF Tampa, Team 5-1, Mcgee Fall 2014人のメンバー
USFT-MCGEE-F14S5G1
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 3,701
