メインコンテンツにスキップ
Motorola Droid 4 Motherboard Housing Replacement
Javier
Javier とその他 4 人の作成者
最終更新日: January 8, 2015
10 - 15 分
中レベル
コミュニティメンバーによる寄稿ガイド
アクションショット
多くの画像が必要
This guide is for the replacement of the motherboard housing. The Motherboard housing encompasses the motherboard and holds it safely. The motherboard is the brain of the phone and should be handled carefully.
You will need to remove several torx head screws. Make sure to use the correct type.
必要な工具と部品
ツール
もっと見る
  1. Motorola Droid 4 Motherboard Housing Replacement, Removing Rear Panel: 手順 1、 3の画像 1 Motorola Droid 4 Motherboard Housing Replacement, Removing Rear Panel: 手順 1、 3の画像 2 Motorola Droid 4 Motherboard Housing Replacement, Removing Rear Panel: 手順 1、 3の画像 3
    • Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
    • Slide the cover down to remove.
  2. Motorola Droid 4 Motherboard Housing Replacement, Battery: 手順 2、 1の画像 1
    • Remove the sticker on the rear compartment to reveal the battery.
    • Hold the battery with your thumb while removing the sticker or you might end up ripping the battery out of the phone, damaging the flex cable.
  3. Motorola Droid 4 Motherboard Housing Replacement: 手順 3、 2の画像 1 Motorola Droid 4 Motherboard Housing Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    T5 Torx Screwdriver
    $5.49
    • Use the T5 Torx Screwdriver to remove both 2.5 mm screws from the battery cable.
    • Use the Spudger to unstick the battery.
    • It's difficult to remove the battery without a pry tool like the spudger because of the strong adhesive. If you try removing it with just your fingers, the battery may bend.
  4. Motorola Droid 4 Motherboard Housing Replacement, Camera Cover Removal: 手順 4、 3の画像 1 Motorola Droid 4 Motherboard Housing Replacement, Camera Cover Removal: 手順 4、 3の画像 2 Motorola Droid 4 Motherboard Housing Replacement, Camera Cover Removal: 手順 4、 3の画像 3
    • Using the blue plastic opening tool, pry off the thin plastic camera cover.
    • The plastic cover is fragile, so proceed carefully.
  5. Motorola Droid 4 Motherboard Housing Replacement, Remove Screws: 手順 5、 2の画像 1 Motorola Droid 4 Motherboard Housing Replacement, Remove Screws: 手順 5、 2の画像 2
    • Remove the four screws, indicated by the red circles, with the screwdriver and T5 Torx bit.
    • The screws are philips 2.5mm. One screw is a different color (silver) from the others (black).
  6. Motorola Droid 4 Motherboard Housing Replacement, Remove Bezel: 手順 6、 3の画像 1 Motorola Droid 4 Motherboard Housing Replacement, Remove Bezel: 手順 6、 3の画像 2 Motorola Droid 4 Motherboard Housing Replacement, Remove Bezel: 手順 6、 3の画像 3
    • Insert the spudger between the rear bezel and the main housing.
    • The bezel is fragile, so proceed carefully.
    • Slide the spudger around all sides of the phone to separate the bezel from the housing.
    • Pry the bezel free.
    • Be careful of the adhesive that holds the bezel to the main housing. Prying too hard may damage your phone.
  7. Motorola Droid 4 Motherboard Housing Replacement, Removing screws: 手順 7、 2の画像 1 Motorola Droid 4 Motherboard Housing Replacement, Removing screws: 手順 7、 2の画像 2
    • Remove the 12 screws holding the housing in place using a T5 Torx screwdriver.
    • Follow the red circles, indicated in the picture, to locate the screws.
    • The 12 screws are (silver) philips 2.5mm
  8. Motorola Droid 4 Motherboard Housing Replacement, Separation of the Housing from the Motherboard: 手順 8、 3の画像 1 Motorola Droid 4 Motherboard Housing Replacement, Separation of the Housing from the Motherboard: 手順 8、 3の画像 2 Motorola Droid 4 Motherboard Housing Replacement, Separation of the Housing from the Motherboard: 手順 8、 3の画像 3
    • Separate the housing from the motherboard.
    • Be careful while separating the housing. The power and volume buttons are easily separated from the housing and can be damaged.
終わりに
作成者
4人の作成者と共同で作成されました。
Javier
メンバー登録日: 09/29/14
533 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 5-1, Mcgee Fall 2014 USF Tampa, Team 5-1, Mcgee Fall 2014人のメンバー
USFT-MCGEE-F14S5G1
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 13
今までの合計 545
