メインコンテンツにスキップ
Motorola Droid 2 Rear Case Replacement
Andrew Bookholt
Andrew Bookholt とその他 3 人の作成者
最終更新日: July 31, 2013
見積もりなし
中レベル
This guide will take you through the delicate process of removing the rear case of the Motorola Droid 2.
必要な工具と部品
ツール
  • Spudger
    Spudger
  • T5 Torx Screwdriver
    T5 Torx Screwdriver
  1. Motorola Droid 2 Rear Case Replacement, Battery: 手順 1、 3の画像 1 Motorola Droid 2 Rear Case Replacement, Battery: 手順 1、 3の画像 2 Motorola Droid 2 Rear Case Replacement, Battery: 手順 1、 3の画像 3
    • Slide the battery cover toward the bottom edge of the phone.
    • Remove the battery cover from the rear of the phone.
  2. Motorola Droid 2 Rear Case Replacement: 手順 2、 2の画像 1 Motorola Droid 2 Rear Case Replacement: 手順 2、 2の画像 2
    • Lift the battery out of the Droid 2 from the edge closest to the bottom of the phone.
    • Remove the battery from the Droid 2.
  3. Motorola Droid 2 Rear Case Replacement, Rear Case: 手順 3、 2の画像 1 Motorola Droid 2 Rear Case Replacement, Rear Case: 手順 3、 2の画像 2
    • Using the tip of a spudger, peel up one corner of the silver ribbon below the battery compartment.
    • Peel the ribbon off the phone.
  4. Motorola Droid 2 Rear Case Replacement: 手順 4、 1の画像 1
    • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
    • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
  5. Motorola Droid 2 Rear Case Replacement: 手順 5、 1の画像 1
    • Use the tip of a spudger to remove the camera bezel stuck to the rear case.
  6. Motorola Droid 2 Rear Case Replacement: 手順 6、 1の画像 1
    • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
  7. Motorola Droid 2 Rear Case Replacement: 手順 7、 1の画像 1
    • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
  8. Motorola Droid 2 Rear Case Replacement: 手順 8、 1の画像 1
    • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
    • Carefully pry the top edge of the rear case up from the rest of the phone.
  9. Motorola Droid 2 Rear Case Replacement: 手順 9、 2の画像 1 Motorola Droid 2 Rear Case Replacement: 手順 9、 2の画像 2
    • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
    • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
  10. Motorola Droid 2 Rear Case Replacement: 手順 10、 2の画像 1 Motorola Droid 2 Rear Case Replacement: 手順 10、 2の画像 2
    • Continue prying the rear case from the front case along the left side, moving from bottom to top.
    • Lift the rear case up out of the phone.
    • At this point, the button covers on the side of the phone are free and may fall out if you tip the phone upside down.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Andrew Bookholt
592,087 ポイント
619のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 14
今までの合計 6,194
