メインコンテンツにスキップ
Motorola California Mobile Phone Rear Casing Replacement
Andrew Lam
Andrew Lam とその他 7 人の作成者
最終更新日: December 28, 2017
1 - 5 分
とても簡単
ツールが不適切
多くの画像が必要
作成途中
ステップトリマー
This guide requires minimal teardown and can be used to replace the plastic back case of the device.
必要な工具と部品
ツール
  1. Motorola California Mobile Phone Rear Casing Replacement, Rear Casing: 手順 1、 1の画像 1
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Motorola California Mobile Phone Rear Casing Replacement: 手順 2、 1の画像 1
    • Find a flat head or Phillips head screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
    • Use the screwdriver to push the rods towards each other until they click out of their locked position.
    • Note: This may require a large amount of force.
  3. Motorola California Mobile Phone Rear Casing Replacement: 手順 3、 1の画像 1
    • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Simultaneously push the clips outward while lifting the old rear casing away from the rest of the device.
  4. Motorola California Mobile Phone Rear Casing Replacement: 手順 4、 1の画像 1
    • Locate the four holes on the new rear casing.
    • Align the holes in the new rear casing with the clips attached the to front casing.
    • Simultaneously insert all four clips.
    • Push down firmly until you hear the clips click into place.
  5. Motorola California Mobile Phone Rear Casing Replacement: 手順 5、 1の画像 1
    • Find a thin and sturdy screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the new key pad guard to the rear casing.
    • Use the screwdriver to push the rods away from each other until they click into their locked position.
終わりに
作成者
7人の作成者と共同で作成されました。
Andrew Lam
メンバー登録日: 04/17/12
53 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 9-46, Regan Spring 2012 Cal Poly, Team 9-46, Regan Spring 2012人のメンバー
CPSU-REGAN-S12S9G46
5 メンバー
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 21
今までの合計 1,037
