メインコンテンツにスキップ
Motorola California Mobile Phone Keypad Guard Replacement
Andrew Caddell
Andrew Caddell とその他 7 人の作成者
最終更新日: January 28, 2014
1 - 5 分
中レベル
ツールが不適切
多くの画像が必要
作成途中
ステップトリマー
Use this guide to replace the keypad guard on the front of the phone.
必要な工具と部品
ツール
  1. Motorola California Mobile Phone Keypad Guard Replacement, Keypad Guard: 手順 1、 1の画像 1
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Motorola California Mobile Phone Keypad Guard Replacement: 手順 2、 1の画像 1
    • Find a flat head or Phillips head screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
    • Use the screwdriver to push the rods towards each other until they click out of their locked position.
    • Note: This may require a large amount of force.
  3. Motorola California Mobile Phone Keypad Guard Replacement: 手順 3、 1の画像 1
    • Slide off the antenna guard.
    • Locate the four clips on the exterior of the rear casing.
    • Simultaneously push the clips outward while lifting the rear casing and keyguard away from the front casing.
    • Remove the old key guard from the rear casing by taking it out of its position.
  4. Motorola California Mobile Phone Keypad Guard Replacement: 手順 4、 1の画像 1
    • Locate the circular extensions protruding from the top of your new key guard.
    • Push inwards on the small tabs on the side of the protrusions until they are no longer sticking out.
    • Note: This may require a strong push.
  5. Motorola California Mobile Phone Keypad Guard Replacement: 手順 5、 1の画像 1
    • Put the back case down on a table in front of you with the bottom of the phone close to you.
    • Put the key guard's tabs into the corresponding tabs on the bottom of the rear casing.
    • While the key guard's tabs are in the rear casing, put the rear casing's tabs into the bottom of the front casing.
  6. Motorola California Mobile Phone Keypad Guard Replacement: 手順 6、 1の画像 1
    • To join the 3 pieces together, push the front and rear casing together so that the clips on the front casing lock into the holes on the rear casing.
    • Slide the antenna guard on.
  7. Motorola California Mobile Phone Keypad Guard Replacement: 手順 7、 1の画像 1
    • Locate the holes that connect the keypad guard to the rear casing.
    • Find a thin and sturdy screwdriver.
    • Use the screwdriver to push the rods away from each other until they click into a locked position.
    • Note: During usage, the key guard will not snap into place if it has not been locked into position.
終わりに
作成者
7人の作成者と共同で作成されました。
Andrew Caddell
メンバー登録日: 04/19/12
10 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 9-46, Regan Spring 2012 Cal Poly, Team 9-46, Regan Spring 2012人のメンバー
CPSU-REGAN-S12S9G46
5 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 17
今までの合計 3,498
