メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Mi 11 Screen Replacement
必要な工具と部品
  1. Mi 11 Screen Replacement, Heat the rear glass: 手順 1、 1の画像 1
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    FixBotに聞いてみる
    コメントを追加
  2. Mi 11 Screen Replacement, Insert an opening pick: 手順 2、 3の画像 1 Mi 11 Screen Replacement, Insert an opening pick: 手順 2、 3の画像 2 Mi 11 Screen Replacement, Insert an opening pick: 手順 2、 3の画像 3
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  3. Mi 11 Screen Replacement, Slice the adhesive: 手順 3、 2の画像 1 Mi 11 Screen Replacement, Slice the adhesive: 手順 3、 2の画像 2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    FixBotに聞いてみる
    コメントを追加
  4. Mi 11 Screen Replacement, Slice the adhesive: 手順 4、 3の画像 1 Mi 11 Screen Replacement, Slice the adhesive: 手順 4、 3の画像 2 Mi 11 Screen Replacement, Slice the adhesive: 手順 4、 3の画像 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your Xiaomi Mi 11 to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  5. Mi 11 Screen Replacement: 手順 5、 2の画像 1 Mi 11 Screen Replacement: 手順 5、 2の画像 2
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  6. Mi 11 Screen Replacement: 手順 6、 2の画像 1 Mi 11 Screen Replacement: 手順 6、 2の画像 2
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
    FixBotに聞いてみる
    コメントを追加
  7. Mi 11 Screen Replacement, Remove the rear glass: 手順 7、 2の画像 1 Mi 11 Screen Replacement, Remove the rear glass: 手順 7、 2の画像 2
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
    FixBotに聞いてみる
    コメントを追加
  8. Mi 11 Screen Replacement, Unfasten the metal bracket screws: 手順 8、 1の画像 1
    • Use a Phillips screwdriver to remove the screws securing the connector metal bracket and the camera cover:
    • Two 4.4 mm-long screws
    • One 4.9 mm-long screw
    • Two 3.9 mm-long screws
    FixBotに聞いてみる
    コメントを追加
  9. Mi 11 Screen Replacement, Remove the metal bracket: 手順 9、 3の画像 1 Mi 11 Screen Replacement, Remove the metal bracket: 手順 9、 3の画像 2 Mi 11 Screen Replacement, Remove the metal bracket: 手順 9、 3の画像 3
    この手順で使用する道具:
    • Use a pair of tweezers to remove the connector bracket by pulling it in the direction of the battery.
    FixBotに聞いてみる
    コメントを追加
  10. Mi 11 Screen Replacement, Disconnect the flash assembly: 手順 10、 2の画像 1 Mi 11 Screen Replacement, Disconnect the flash assembly: 手順 10、 2の画像 2
    • Use the pointed end of a spudger to disconnect the flash assembly cable by prying the connector straight up from its socket.
    FixBotに聞いてみる
    コメントを追加
  11. Mi 11 Screen Replacement, Disconnect the right battery cable: 手順 11、 2の画像 1 Mi 11 Screen Replacement, Disconnect the right battery cable: 手順 11、 2の画像 2
    • The battery of the Xiaomi Mi 11 has two separate flex cables. You need to disconnect both in order to disconnect the battery completely.
    • Use a spudger to disconnect the right battery cable by prying the connector straight up from its socket.
    FixBotに聞いてみる
    コメントを追加
  12. Mi 11 Screen Replacement, Remove the camera cover: 手順 12、 2の画像 1 Mi 11 Screen Replacement, Remove the camera cover: 手順 12、 2の画像 2
    • Use your fingers or a pair of tweezers to carefully lift the camera cover including the flash assembly off the camera lenses and remove it.
    FixBotに聞いてみる
    コメントを追加
  13. Mi 11 Screen Replacement, Unfasten the motherboard cover screws: 手順 13、 1の画像 1
    • Use a Phillips screwdriver to remove the five 3.9 mm-long screws securing the motherboard cover.
    FixBotに聞いてみる
    コメントを追加
  14. Mi 11 Screen Replacement, Pry up the motherboard cover: 手順 14、 2の画像 1 Mi 11 Screen Replacement, Pry up the motherboard cover: 手順 14、 2の画像 2
    • Insert an opening pick underneath the bottom left edge of the motherboard cover.
    • Slide the opening pick along the left edge of the motherboard cover and pry it up.
    FixBotに聞いてみる
    コメントを追加
  15. Mi 11 Screen Replacement, Remove the motherboard cover: 手順 15、 2の画像 1 Mi 11 Screen Replacement, Remove the motherboard cover: 手順 15、 2の画像 2
    • Remove the motherboard cover.
    FixBotに聞いてみる
    コメントを追加
  16. Mi 11 Screen Replacement, Disconnect the left battery cable: 手順 16、 2の画像 1 Mi 11 Screen Replacement, Disconnect the left battery cable: 手順 16、 2の画像 2
    • Use a spudger to disconnect the left battery cable by prying the connector straight up from its socket.
    FixBotに聞いてみる
    コメントを追加
  17. Mi 11 Screen Replacement, Disconnect the right interconnect cable: 手順 17、 2の画像 1 Mi 11 Screen Replacement, Disconnect the right interconnect cable: 手順 17、 2の画像 2
    • Use a spudger to disconnect the right interconnect cable from the motherboard by prying the connector straight up from its socket.
    FixBotに聞いてみる
    コメントを追加
  18. Mi 11 Screen Replacement, Remove the right interconnect cable: 手順 18、 3の画像 1 Mi 11 Screen Replacement, Remove the right interconnect cable: 手順 18、 3の画像 2 Mi 11 Screen Replacement, Remove the right interconnect cable: 手順 18、 3の画像 3
    • Use a spudger to disconnect the right interconnect cable from the daughterboard by prying the connector straight up from its socket.
    • Remove the right interconnect cable.
    FixBotに聞いてみる
    コメントを追加
  19. Mi 11 Screen Replacement, Disconnect the display flex cable: 手順 19、 2の画像 1 Mi 11 Screen Replacement, Disconnect the display flex cable: 手順 19、 2の画像 2
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
    FixBotに聞いてみる
    コメントを追加
  20. Mi 11 Screen Replacement, Loosen the display adhesive: 手順 20、 1の画像 1
    • Apply a heated iOpener or a heat gun to the screen for two minutes to loosen the adhesive underneath.
    FixBotに聞いてみる
    コメントを追加
  21. Mi 11 Screen Replacement, Insert an opening pick: 手順 21、 3の画像 1 Mi 11 Screen Replacement, Insert an opening pick: 手順 21、 3の画像 2 Mi 11 Screen Replacement, Insert an opening pick: 手順 21、 3の画像 3
    • Once the screen is warm to the touch, apply a suction cup to the bottom edge of the phone.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick in the gap between the midframe and the screen.
    • Slide the opening pick to the bottom right corner of the screen to slice its adhesive. Leave the opening pick in place to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  22. Mi 11 Screen Replacement, Slice the adhesive: 手順 22、 2の画像 1 Mi 11 Screen Replacement, Slice the adhesive: 手順 22、 2の画像 2
    • Insert a second opening pick and slide it to the bottom left corner of the screen to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  23. Mi 11 Screen Replacement: 手順 23、 3の画像 1 Mi 11 Screen Replacement: 手順 23、 3の画像 2 Mi 11 Screen Replacement: 手順 23、 3の画像 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun to for 1-2 minutes to reheat it.
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive. Leave it in the top left corner to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  24. Mi 11 Screen Replacement: 手順 24、 2の画像 1 Mi 11 Screen Replacement: 手順 24、 2の画像 2
    • When you slice near the front facing camera, insert only the tip of the opening pick to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner of the screen to prevent the adhesive from resealing.
    FixBotに聞いてみる
    コメントを追加
  25. Mi 11 Screen Replacement: 手順 25、 2の画像 1 Mi 11 Screen Replacement: 手順 25、 2の画像 2
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
    • Do not try to remove the display all the way yet, the display cable is still threaded through the frame.
    FixBotに聞いてみる
    コメントを追加
  26. Mi 11 Screen Replacement, Remove the screen: 手順 26、 3の画像 1 Mi 11 Screen Replacement, Remove the screen: 手順 26、 3の画像 2 Mi 11 Screen Replacement, Remove the screen: 手順 26、 3の画像 3
    • Thread the display flex cable through the gap in the midframe and remove the screen.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, follow this guide in case you're using a pre-cut adhesive card.
    FixBotに聞いてみる
    コメントを追加
終わりに
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
キャンセル: このガイドを終了できませんでした。
9 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Dominik Schnabelrauch
メンバー登録日: 11/23/16
261,029 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
28,226のガイドは作成済み
2件のガイドコメント
After new screen substitution is Impossible to add new fingerprint
Aldo Della Monica - 返信 共有
You need to calibrate the fingerprint sensor. There are guides on Youtube and parts on Aliexpress
Nicolas SCHMIT - 返信 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 40
過去 30 日: 192
今までの合計 14,812
