メインコンテンツにスキップ
MSI MS-1782 Speaker Assembly Replacement
A'kia
A'kia とその他 2 人の作成者
最終更新日: June 1, 2023
20分
中レベル
より良い紹介部分
Using the MSI MS-1782, encountering trouble with the speakers, you will use this guide to replace the speakers. It is important to disconnect the battery before replacing the speakers.
必要な工具と部品
ツール
  1. MSI MS-1782 Speaker Assembly Replacement, Back Cover: 手順 1、 1の画像 1
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Speaker Assembly Replacement: 手順 2、 3の画像 1 MSI MS-1782 Speaker Assembly Replacement: 手順 2、 3の画像 2 MSI MS-1782 Speaker Assembly Replacement: 手順 2、 3の画像 3
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
  3. MSI MS-1782 Speaker Assembly Replacement, Cooling Assembly: 手順 3、 3の画像 1 MSI MS-1782 Speaker Assembly Replacement, Cooling Assembly: 手順 3、 3の画像 2 MSI MS-1782 Speaker Assembly Replacement, Cooling Assembly: 手順 3、 3の画像 3
    • Loosen the captive screw on the left side of the left fan using a JIS #2 screwdriver.
    • Remove the 5.1 mm screw on the right side of the left fan using a JIS #2 screwdriver.
  4. MSI MS-1782 Speaker Assembly Replacement: 手順 4、 3の画像 1 MSI MS-1782 Speaker Assembly Replacement: 手順 4、 3の画像 2 MSI MS-1782 Speaker Assembly Replacement: 手順 4、 3の画像 3
    • Gently detach the fan connector.
    • Remove the fan by lifting it out of its housing.
    • Be sure to handle the wire delicately; if not it will break.
  5. MSI MS-1782 Speaker Assembly Replacement: 手順 5、 3の画像 1 MSI MS-1782 Speaker Assembly Replacement: 手順 5、 3の画像 2 MSI MS-1782 Speaker Assembly Replacement: 手順 5、 3の画像 3
    • Loosen the captive screw on the top of the right fan using a JIS #2 screwdriver.
    • Remove the 3.6 mm screw on the bottom of the right fan using a JIS #2 screwdriver.
  6. MSI MS-1782 Speaker Assembly Replacement: 手順 6、 3の画像 1 MSI MS-1782 Speaker Assembly Replacement: 手順 6、 3の画像 2 MSI MS-1782 Speaker Assembly Replacement: 手順 6、 3の画像 3
  7. MSI MS-1782 Speaker Assembly Replacement: 手順 7、 3の画像 1 MSI MS-1782 Speaker Assembly Replacement: 手順 7、 3の画像 2 MSI MS-1782 Speaker Assembly Replacement: 手順 7、 3の画像 3
    • Loosen the eight captive screws holding the heat sink in place using a JIS #2 screwdriver.
    • Be sure to follow the numbers that are next to the screws on the heatsink. This evenly removes pressure on the components when removing the heatsink.
  8. MSI MS-1782 Speaker Assembly Replacement: 手順 8、 3の画像 1 MSI MS-1782 Speaker Assembly Replacement: 手順 8、 3の画像 2 MSI MS-1782 Speaker Assembly Replacement: 手順 8、 3の画像 3
    • Gently lift the heat sink and then pull forwards towards you.
  9. MSI MS-1782 Speaker Assembly Replacement, Battery: 手順 9、 3の画像 1 MSI MS-1782 Speaker Assembly Replacement, Battery: 手順 9、 3の画像 2 MSI MS-1782 Speaker Assembly Replacement, Battery: 手順 9、 3の画像 3
    • Remove the four 5.5 mm screws holding the battery frame in place using a JIS #1 screwdriver.
    • Gently disconnect the cable connecting the M.2 caddy to the motherboard.
  10. MSI MS-1782 Speaker Assembly Replacement: 手順 10、 3の画像 1 MSI MS-1782 Speaker Assembly Replacement: 手順 10、 3の画像 2 MSI MS-1782 Speaker Assembly Replacement: 手順 10、 3の画像 3
    • Remove the 3.6 mm screw holding the M.2 caddy in place using a JIS #1 screwdriver.
  11. MSI MS-1782 Speaker Assembly Replacement: 手順 11、 3の画像 1 MSI MS-1782 Speaker Assembly Replacement: 手順 11、 3の画像 2 MSI MS-1782 Speaker Assembly Replacement: 手順 11、 3の画像 3
    • Gently disconnect the two blue ribbons.
  12. MSI MS-1782 Speaker Assembly Replacement: 手順 12、 3の画像 1 MSI MS-1782 Speaker Assembly Replacement: 手順 12、 3の画像 2 MSI MS-1782 Speaker Assembly Replacement: 手順 12、 3の画像 3
    • Remove the 5.1 mm screw holding in the disk reader using a JIS #1 screwdriver.
    • Use an iFixit opening tool to push the back of the disk reader to push it out of the laptop's chassis.
  13. MSI MS-1782 Speaker Assembly Replacement: 手順 13、 3の画像 1 MSI MS-1782 Speaker Assembly Replacement: 手順 13、 3の画像 2 MSI MS-1782 Speaker Assembly Replacement: 手順 13、 3の画像 3
    • Gently pull the disc reader out of the laptop.
    • Lift the plastic cover and disconnect the cable connected next to the speaker.
  14. MSI MS-1782 Speaker Assembly Replacement: 手順 14、 1の画像 1
    • Remove the five 5 mm screws holding the frame in place using a JIS #1 screwdriver.
  15. MSI MS-1782 Speaker Assembly Replacement: 手順 15、 3の画像 1 MSI MS-1782 Speaker Assembly Replacement: 手順 15、 3の画像 2 MSI MS-1782 Speaker Assembly Replacement: 手順 15、 3の画像 3
    • Pry up on the battery frame with an opening tool and unclip from the main chassis, working your way around the laptop.
    • To remove the battery, pry up on it to unstick the adhesive.
    • A little Isopropyl alcohol under the battery can help unstick it from the frame.
  16. MSI MS-1782 Speaker Assembly Replacement, Speaker Assembly: 手順 16、 2の画像 1 MSI MS-1782 Speaker Assembly Replacement, Speaker Assembly: 手順 16、 2の画像 2
    • Pull the left speaker out, following the wire, unclipping it as you go to the next.
  17. MSI MS-1782 Speaker Assembly Replacement: 手順 17、 2の画像 1 MSI MS-1782 Speaker Assembly Replacement: 手順 17、 2の画像 2
    • Pull the right speaker out. Unclip the wire as you go, now completely removing both speakers.
  18. MSI MS-1782 Speaker Assembly Replacement: 手順 18、 3の画像 1 MSI MS-1782 Speaker Assembly Replacement: 手順 18、 3の画像 2 MSI MS-1782 Speaker Assembly Replacement: 手順 18、 3の画像 3
    • Unplug the subwoofer and lift vertically to remove.
終わりに
作成者
2人の作成者と共同で作成されました。
A'kia
メンバー登録日: 03/08/23
193 ポイント
2のガイドは作成済み
チーム
University of New Orleans, Team 4-4, McDonald Spring 2023 University of New Orleans, Team 4-4, McDonald Spring 2023人のメンバー
UNO-MCDONALD-S23S4G4
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 14
今までの合計 106
