メインコンテンツにスキップ
LaCie USB2 Desktop Hard Drive Internal Hard Disk Replacement
Diemo Schwarz
Diemo Schwarz とその他 人の作成者
最終更新日: July 26, 2024
15分
中レベル
文法の修正
コミュニティメンバーによる寄稿ガイド
This LaCie external hard drive came in 500GB and 1TB sizes, at least. It must be from before 2010, later replaced by the Neil Poulton design with blue LED lighting towards the bottom (which opens completely differently).
必要な工具と部品
ツール
  1. LaCie USB2 Desktop Hard Drive Internal Hard Disk Replacement, Open the Enclosure: 手順 1、 3の画像 1 LaCie USB2 Desktop Hard Drive Internal Hard Disk Replacement, Open the Enclosure: 手順 1、 3の画像 2 LaCie USB2 Desktop Hard Drive Internal Hard Disk Replacement, Open the Enclosure: 手順 1、 3の画像 3
    • turn the enclosure upside down
    • there are 2 little openings at the back plate (with the USB and power sockets, at the top of the image) where you can use a flat screwdriver to pry the plate open a little
    • when the edges are loose, you can slide the back plate upwards
    • with the back plate removed, you can push the inner frame holding the hard drive out of the metal enclosure
  2. LaCie USB2 Desktop Hard Drive Internal Hard Disk Replacement, Remove Hard Drive: 手順 2、 2の画像 1 LaCie USB2 Desktop Hard Drive Internal Hard Disk Replacement, Remove Hard Drive: 手順 2、 2の画像 2
    • remove the 2 screws that hold the little controller PCB down
    • lift the internal hard drive at the other end (by wiggling the enclosure turned upside down to let it gently come out) just enough so that it can be disconnected from the SATA port
    • be careful to not break the connector on the PCB (which is still fixed to the internal back plate with the USB and power sockets)
  3. LaCie USB2 Desktop Hard Drive Internal Hard Disk Replacement, Replace Internal Drive and Reassemble: 手順 3、 1の画像 1
    • slide in the new drive in the same manner, slightly lifting the SATA connector on the PCD
    • reassemble by following the steps backwards
終わりに
作成者
1人の作成者と共同作成されました。
Diemo Schwarz
メンバー登録日: 01/22/22
275 ポイント
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 44
今までの合計 536
