メインコンテンツにスキップ
LG K7 T-Mobile Motherboard Replacement
必要な工具と部品
  1. LG K7 T-Mobile Motherboard Replacement, Battery: 手順 1、 2の画像 1 LG K7 T-Mobile Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • Flip the LG K7 over so that the back of the phone is facing up.
    • Locate the small notch on the bottom left side of the phone.
  2. LG K7 T-Mobile Motherboard Replacement: 手順 2、 1の画像 1
    • Insert a plastic opening tool into the notch and lift the back cover upward while holding the bottom portion of the phone down to remove it.
  3. LG K7 T-Mobile Motherboard Replacement: 手順 3、 1の画像 1
    • Remove the battery.
  4. LG K7 T-Mobile Motherboard Replacement, Motherboard: 手順 4、 2の画像 1 LG K7 T-Mobile Motherboard Replacement, Motherboard: 手順 4、 2の画像 2
    • Located to nine 3.4 mm screws that keep that keep the phones rear housing in tacked.
    • Using a Phillips 00 screwdriver remove all nine 3.4 mm screws.
  5. LG K7 T-Mobile Motherboard Replacement: 手順 5、 3の画像 1 LG K7 T-Mobile Motherboard Replacement: 手順 5、 3の画像 2 LG K7 T-Mobile Motherboard Replacement: 手順 5、 3の画像 3
    • Turn the phone over so the screen is facing up.
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seams carefully to separate the screen from the rest of the phone housing.
  6. LG K7 T-Mobile Motherboard Replacement: 手順 6、 3の画像 1 LG K7 T-Mobile Motherboard Replacement: 手順 6、 3の画像 2 LG K7 T-Mobile Motherboard Replacement: 手順 6、 3の画像 3
    • Locate the lock that holds the camera's ribbon cable in place.
    • Carefully remove the camera's ribbon cable from the motherboard using the plastic removal tool.
    • Holding the camera ribbon you just released pull upwards and the camera should release from the case.
  7. LG K7 T-Mobile Motherboard Replacement: 手順 7、 2の画像 1 LG K7 T-Mobile Motherboard Replacement: 手順 7、 2の画像 2
    • Locate the headphone jack towards the bottom right of the phone.
    • Place a plastic removal tool underneath the head phone jack.
    • Lift the plastic removal tool upward to remove the earphone jack from the phone case.
  8. LG K7 T-Mobile Motherboard Replacement: 手順 8、 2の画像 1 LG K7 T-Mobile Motherboard Replacement: 手順 8、 2の画像 2
    • Locate the ribbon for the front facing camera.
    • Carefully remove the front facing camera's ribbon cable from the motherboard using the plastic removal tool.
    • Holding the front camera ribbon you just released pull upwards and the camera should release from the case.
    • Remove the band that connects the screen display to the motherboard.
  9. LG K7 T-Mobile Motherboard Replacement: 手順 9、 2の画像 1 LG K7 T-Mobile Motherboard Replacement: 手順 9、 2の画像 2
    • Locate the ribbon cable that connects the screen to the motherboard.
    • Carefully remove the screen's ribbon cable from the motherboard using the plastic removal tool by lifting the ribbon cable upwards.
  10. LG K7 T-Mobile Motherboard Replacement: 手順 10、 3の画像 1 LG K7 T-Mobile Motherboard Replacement: 手順 10、 3の画像 2 LG K7 T-Mobile Motherboard Replacement: 手順 10、 3の画像 3
    • Wedge a plastic opening tool between the motherboard and the phones casing.
    • While using one finger to hold down a portion of the phone pull upwards with the plastic opening tool to loosen the motherboard from the phone casing.
    • Once there is some space between the board and the phone case, using your hands carefully lift the motherboard from the phone casing.
終わりに
7 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Brandon Jones
メンバー登録日: 09/28/17
233 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S2-G5, Nance Fall 2017 USF Tampa, Team S2-G5, Nance Fall 2017人のメンバー
USFT-NANCE-F17S2G5
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 2,167
