メインコンテンツにスキップ
LG K7 Rear Facing Camera Replacement
James Ngo
James Ngo とその他 人の作成者
最終更新日: December 8, 2021
10分
中レベル
Your rear camera may be broken, cracked, or otherwise not working. This guide will instruct you on how to remove your faulty rear camera.
必要な工具と部品
ツール
  1. LG K7 Rear Facing Camera Replacement, Battery: 手順 1、 2の画像 1 LG K7 Rear Facing Camera Replacement, Battery: 手順 1、 2の画像 2
    • Place a fingernail in slot at in the bottom edge of the phone.
    • Pull up on the back panel while holding down the rest of the phone steady with your hand.
    • Do not to pull too hard on the back panel or you may break it.
  2. LG K7 Rear Facing Camera Replacement: 手順 2、 2の画像 1 LG K7 Rear Facing Camera Replacement: 手順 2、 2の画像 2
    • Place a fingernail in the slot at the bottom edge of the battery.
    • Pull the battery out.
  3. LG K7 Rear Facing Camera Replacement, Rear Facing Camera: 手順 3、 3の画像 1 LG K7 Rear Facing Camera Replacement, Rear Facing Camera: 手順 3、 3の画像 2 LG K7 Rear Facing Camera Replacement, Rear Facing Camera: 手順 3、 3の画像 3
    • Remove the 9 frame screws with a JIS #00 screwdriver.
    • The bottom three screws release the port cover at the bottom of the phone. The cover should lift off easily once the screws are out.
    • Pop the camera button frame off with a spudger. The home button should come off along with the frame.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
  4. LG K7 Rear Facing Camera Replacement: 手順 4、 2の画像 1 LG K7 Rear Facing Camera Replacement: 手順 4、 2の画像 2
    • Use a plastic opening tool to separate the screen from the outer frame.
    • Do not to bend the outer frame or the screen to when separating them. This can severely damage the phone.
  5. LG K7 Rear Facing Camera Replacement: 手順 5、 1の画像 1
    • Insert the edge of a plastic opening tool underneath the camera connector that is attached to the camera by a flat, thin, and flexible sheet.
    • Slowly lever the connector free by pressing down on the opening tool's handle. The connector should be fairly solid and pop out by levering just one edge.
    • Be careful not to break or bend the connector or any part of the device you may be levering against.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
James Ngo
メンバー登録日: 01/19/18
461 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S21-G5, Banghart Winter 2018 Cal Poly, Team S21-G5, Banghart Winter 2018人のメンバー
CPSU-BANGHART-W18S21G5
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 6
過去 30 日: 6
今までの合計 431
