LG K7 Charging Port Replacement
はじめに
手順 1 に進むThe charging port allows for the LG K7 to be charged. It can stop working for a number of reasons but the main two are shock and wear. It can be replaced in about 30 minutes with the guide below. A soldering iron will be necessary which should be used with caution.
Remove the back cover by using the plastic opening tool.
Remove battery by using the plastic opening tool.
ある他の人がこのガイドを完成しました。
