メインコンテンツにスキップ
KitchenAid Classic Mixer K45SSWH Beater Head Adjustment
Markus Gemperle
Markus Gemperle とその他 3 人の作成者
最終更新日: January 25, 2022
1 - 2 分
とても簡単
Adjusting the beater head is a simple process involving only some handling of a screwdriver.
必要な工具と部品
  1. KitchenAid Classic Mixer K45SSWH Beater Head Adjustment, Adjust the height: 手順 1、 2の画像 1 KitchenAid Classic Mixer K45SSWH Beater Head Adjustment, Adjust the height: 手順 1、 2の画像 2
    • Lift the mixer arm and locate the large screw where the base meets the arm.
    • Using a flathead screwdriver, turn the screw counter-clockwise to raise the beater head or turn it clockwise to lower the beater head.
    • The beater head should pass only about 1/16th of an inch above the base of the bowl. One good way to get the height right is to place a dime in the bowl and adjust the height until the beater head barely brushes the dime as it passes.
終わりに
Once your beater head is at the appropriate height, you're good to go.
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Markus Gemperle
メンバー登録日: 10/13/14
720 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 14-28, Maness Fall 2014 Cal Poly, Team 14-28, Maness Fall 2014人のメンバー
CPSU-MANESS-F14S14G28
4 メンバー
22のガイドは作成済み
2ガイドコメント
Very helpful. Thank you for the info, it worked!!
suz - 返信
I have a K5ss by Hobbart. Do you know how to adjust the bowl/beater clearance.?This machine does not have the screw that adjusts the clearance like the K45ss does. The manual tells how to turn a screw to adjust the clearance on a k45ss, but says to consult an authorized dealer for the k5ss. I called around and nobody in my area works on mixers. Is this something I can do myself? Any help would be appreciated.
Aide L. - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 25
過去 30 日: 140
今までの合計 14,928
