メインコンテンツにスキップ
Kirby G5 Vacuum Belt Replacement
Gina Trojano
Gina Trojano とその他 2 人の作成者
最終更新日: August 14, 2024
10分
簡単
高画質の画像が必要
Sometimes our vacuums seem to leave messes instead of cleaning them up. This can happen due to the vacuum belt being worn down or breaking apart. With being such an easy fix, some people fail to realize this and buy a brand new vacuum instead of taking a closer look. Here, we will be slowing it down for a second to help just about anyone learn to change a belt and hopefully save some money the next time their vacuum stops doing its job. This guide will show you how to replace the belt in a Kirby G5 vacuum cleaner. Be sure to get the correct replacement belt for your vacuum.
必要な工具と部品
  1. Kirby G5 Vacuum Belt Replacement, Vacuum Belt: 手順 1、 1の画像 1
    • Place the vacuum at an angle most comfortable and easy to access with the bottom facing upwards.
  2. Kirby G5 Vacuum Belt Replacement: 手順 2、 2の画像 1 Kirby G5 Vacuum Belt Replacement: 手順 2、 2の画像 2
    • Remove the three screws holding the base plate to the body of the vacuum using a flat head screwdriver.
    • Place the plate to the side.
  3. Kirby G5 Vacuum Belt Replacement: 手順 3、 1の画像 1
    • Simply slide the roller out of the vacuum.
    • The belt is attached to the roller on either side.
  4. Kirby G5 Vacuum Belt Replacement: 手順 4、 2の画像 1 Kirby G5 Vacuum Belt Replacement: 手順 4、 2の画像 2
    • Slide the vacuum belt out from beneath the wheel holding it in place.
  5. Kirby G5 Vacuum Belt Replacement: 手順 5、 1の画像 1
    • Insert your new belt and pop the roller back into place.
  6. Kirby G5 Vacuum Belt Replacement: 手順 6、 2の画像 1 Kirby G5 Vacuum Belt Replacement: 手順 6、 2の画像 2
    • Secure the plate once again until it clicks into the made grooves.
    • Secure the three screws until tightened.
終わりに
Make sure to test the vacuum and securely tighten all screws. With that, you’re good to go!
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Gina Trojano
メンバー登録日: 04/22/21
157 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team S2-G23, Sinclaire Spring 2021 UMass Dartmouth, Team S2-G23, Sinclaire Spring 2021人のメンバー
UMASSD-SINCLAIRE-S21S2G23
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 40
今までの合計 1,457
