メインコンテンツにスキップ
JYX-S55 Speaker Replacement
Alexandra Wehrhahn
Alexandra Wehrhahn とその他 2 人の作成者
最終更新日: June 1, 2023
30分 - 1時間
中レベル
If your JYX-S55 speaker isn't producing sound, or if the sound appears highly distorted or muffled, use this guide to replace the woofer (the sound mechanism inside the speaker).
The woofer allows the device to produce quality sound.
Before using this guide, inspect the charging cable of the device and attempt to charge the device using other charging cables that fit into the USB-C charging port located on the top panel of the device. This will confirm whether or not the woofer is faulty within the device, as low charge can impact the sound quality of the device.
To reduce risk while completing the replacement, make sure the battery is completely discharged by leaving the device on until it turns off. This will signal the battery is not carrying any charge, and it is safer to replace any component of the device. Keep the device off and unplugged from all external power sources at all times while replacing any component.
必要な工具と部品
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. JYX-S55 Speaker Replacement, Speaker: 手順 1、 2の画像 1 JYX-S55 Speaker Replacement, Speaker: 手順 1、 2の画像 2
    • Remove the four screws from the top panel of the device using a 2.5 hex screwdriver.
    • Remove the top panel.
  2. JYX-S55 Speaker Replacement: 手順 2、 1の画像 1
    • Remove the four screws that keep the light strip in place using a JIS #1 screwdriver.
  3. JYX-S55 Speaker Replacement: 手順 3、 2の画像 1 JYX-S55 Speaker Replacement: 手順 3、 2の画像 2
    • Lift out the plastic ring which contains the lights.
    • The lights will be connected with wires. These do not need to be cut or ripped out; simply place the plastic ring off to the side or somewhere out of the way.
  4. JYX-S55 Speaker Replacement: 手順 4、 1の画像 1
    • Remove the four screws at the corners of the woofer/speaker using a JIS #1 screwdriver.
  5. JYX-S55 Speaker Replacement: 手順 5、 1の画像 1
    • Pull out the speaker’s woofer.
  6. JYX-S55 Speaker Replacement: 手順 6、 2の画像 1 JYX-S55 Speaker Replacement: 手順 6、 2の画像 2
    • Use a pair of wire cutters to separate the speaker from the rest of the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Alexandra Wehrhahn
メンバー登録日: 03/04/23
151 ポイント
1ガイドが承認済み
チーム
Marist, Team 1-5, Chaterdon Spring 2023 Marist, Team 1-5, Chaterdon Spring 2023人のメンバー
MARS-CHATERDON-S23S1G5
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 18
今までの合計 435
