メインコンテンツにスキップ
Huawei Honor 6x Battery Replacement
Hudson Brooks
Hudson Brooks とその他 5 人の作成者
最終更新日: March 4, 2024
20 - 40 分
中レベル
おすすめの学生による修理ガイド
This guide will detail how to remove and replace the battery of the Huawei Honor 6x. The battery needs to be replaced when it loses charge faster than expected, or when it is broken.
必要な工具と部品
ツール
もっと見る
  1. Huawei Honor 6x Battery Replacement, SIM Card: 手順 1、 1の画像 1
    • Turn off the device.
  2. Huawei Honor 6x Battery Replacement: 手順 2、 2の画像 1 Huawei Honor 6x Battery Replacement: 手順 2、 2の画像 2
    • Insert the SIM Card Eject Tool into the SIM card tray hole.
    • Press the eject tool into the hole until the tray clicks open.
  3. Huawei Honor 6x Battery Replacement: 手順 3、 1の画像 1
    • Remove the SIM tray from the device using two fingers.
    • When reinserting the SIM card, be sure it is properly aligned with the SIM tray.
  4. Huawei Honor 6x Battery Replacement: 手順 4、 1の画像 1
    • Remove the SIM card from the compartment using two fingers.
  5. Huawei Honor 6x Battery Replacement, Back Cover: 手順 5、 2の画像 1 Huawei Honor 6x Battery Replacement, Back Cover: 手順 5、 2の画像 2
    • Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
    • Pry the screen off the back of the phone by pushing down on the opening tool.
  6. Huawei Honor 6x Battery Replacement: 手順 6、 3の画像 1 Huawei Honor 6x Battery Replacement: 手順 6、 3の画像 2 Huawei Honor 6x Battery Replacement: 手順 6、 3の画像 3
    • Slide the opening tool or spudger along the bottom of the phone and around the edge.
  7. Huawei Honor 6x Battery Replacement: 手順 7、 2の画像 1 Huawei Honor 6x Battery Replacement: 手順 7、 2の画像 2
    • Once three sides of the screen are detached, pry the phone apart using two hands.
    • When separating the back panel from the screen, do not pull them too far apart. There is an interconnect that is attached to both sides that could break, or tear, if pulled too far.
  8. Huawei Honor 6x Battery Replacement: 手順 8、 3の画像 1 Huawei Honor 6x Battery Replacement: 手順 8、 3の画像 2 Huawei Honor 6x Battery Replacement: 手順 8、 3の画像 3
    • Remove the five 4mm Phillips #00 screws using a screwdriver.
  9. Huawei Honor 6x Battery Replacement: 手順 9、 1の画像 1
    • Remove the motherboard cover from the device using a spudger or your fingers.
  10. Huawei Honor 6x Battery Replacement, Battery: 手順 10、 2の画像 1 Huawei Honor 6x Battery Replacement, Battery: 手順 10、 2の画像 2
    • Remove the four connectors by placing the spudger between the motherboard and the connectors.
    • Press upwards against the connectors until they disconnect.
    • The connectors will make a "click" sound when disconnected.
  11. Huawei Honor 6x Battery Replacement: 手順 11、 2の画像 1 Huawei Honor 6x Battery Replacement: 手順 11、 2の画像 2
    • Remove the battery by first prying a spudger between the battery and the screen.
    • Slice through the adhesive by pushing card around and underneath the battery.
    • The adhesive is fairly strong, so make sure to press firmly against the adhesive.
    • Do not excessively bend the battery. Bending the battery too much can cause it to break and even catch fire.
  12. Huawei Honor 6x Battery Replacement: 手順 12、 2の画像 1 Huawei Honor 6x Battery Replacement: 手順 12、 2の画像 2
    この手順で使用する道具:
    Plastic Cards
    $2.99
    • Using the plastic card, remove the battery by lifting it from the casing.
終わりに
16 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Hudson Brooks
メンバー登録日: 10/08/18
495 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S13-G5, White Fall 2018 Cal Poly, Team S13-G5, White Fall 2018人のメンバー
CPSU-WHITE-F18S13G5
4 メンバー
14のガイドは作成済み
3 件のコメント
Where do i get its original battery, its mostly fake batteries out there in online stores
satyanarayan debbarma - 返信
@satyanarayan+debbarma
I used this battery I found on Amazon. It wasn’t the original, by Huawei, but it’s the exact same thing. Works perfectly fine.
https://www.amazon.com/gp/product/B08LZC...
Varler - 返信
Thanks very much
Eng Dhr moh - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 32
過去 30 日: 89
今までの合計 10,706
