メインコンテンツにスキップ
iFixit uses cookies to enhance site functionality, analyze traffic, and personalize ads. By using our site, you agree to our cookie use and Privacy Policy.
How to Replace a Bicycle Bell Disc
Susan
Susan とその他 2 人の作成者
最終更新日: May 12, 2024
4分
簡単
If your bicycle bell isn't ringing, it's likely because the internal arms aren't rotating well or at all. This guide demonstrates how to quickly replace the rotating discs inside the bell, and get it back into working order. This is a quick fix that does not require any tools.
必要な工具と部品
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. How to Replace a Bicycle Bell Disc, Disc Bell: 手順 1、 2の画像 1 How to Replace a Bicycle Bell Disc, Disc Bell: 手順 1、 2の画像 2
    • Unscrew the exterior bell housing by rotating clockwise, then remove the housing.
  2. How to Replace a Bicycle Bell Disc: 手順 2、 2の画像 1 How to Replace a Bicycle Bell Disc: 手順 2、 2の画像 2
    • Rotate the parallel bars clockwise until they separate from the rod they're mounted on.
  3. How to Replace a Bicycle Bell Disc: 手順 3、 2の画像 1 How to Replace a Bicycle Bell Disc: 手順 3、 2の画像 2
    • Remove the rubber discs.
    • Grab your new rubber discs and insert one at each end of the parallel bars.
    • Make sure center of the rubber discs are held in place by the pins.
  4. How to Replace a Bicycle Bell Disc: 手順 4、 1の画像 1
    • Test and rotate the discs with your finger to see if it is the appropriate size.
    • If the disc does not rotate easily, change the size of your metal disc to a narrower one.
  5. How to Replace a Bicycle Bell Disc: 手順 5、 2の画像 1 How to Replace a Bicycle Bell Disc: 手順 5、 2の画像 2
    • Rotate the parallel bars counterclockwise, into their original position.
  6. How to Replace a Bicycle Bell Disc: 手順 6、 2の画像 1 How to Replace a Bicycle Bell Disc: 手順 6、 2の画像 2
    • Replace the exterior housing and rotate it counterclockwise until it's fully secure.
終わりに
Your bell should now be ringing like new!
作成者
2人の作成者と共同で作成されました。
Susan
メンバー登録日: 01/19/22
133 ポイント
1ガイドが承認済み
チーム
York University, Team N-10, O'Regan Winter 2022 York University, Team N-10, O'Regan Winter 2022人のメンバー
YORK-O'REGAN-W22SNG10
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 57
今までの合計 1,243
