メインコンテンツにスキップ
How to Refill Canon Pixma MG3550 Ink Cartridges
Kayun Kim
Kayun Kim とその他 人の作成者
最終更新日: August 30, 2023
5分
簡単
If you have a Canon Pixma MG3550 printer at home, it is likely that you have seen the low ink warning and had to replace an ink cartridge. However, buying new ink cartridges can be very expensive.
You can use this guide to refill the cartridge and save money and also help the environment from throwing them out.
You will need red, yellow, blue, and black ink and 4 syringes for the inks. These are available on Amazon.
必要な工具と部品
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. How to Refill Canon Pixma MG3550 Ink Cartridges, How to Refill Canon Pixma MG3550 Ink Cartridges: 手順 1、 2の画像 1 How to Refill Canon Pixma MG3550 Ink Cartridges, How to Refill Canon Pixma MG3550 Ink Cartridges: 手順 1、 2の画像 2
    • Prepare materials.
    • You will need red, yellow, blue, and black ink and 4 syringes for the inks. These are available on Amazon.
    • Paper towel and gloves are not required but recommended.
  2. How to Refill Canon Pixma MG3550 Ink Cartridges: 手順 2、 3の画像 1 How to Refill Canon Pixma MG3550 Ink Cartridges: 手順 2、 3の画像 2 How to Refill Canon Pixma MG3550 Ink Cartridges: 手順 2、 3の画像 3
    • Open the printer cover and take out the ink cartridge.
  3. How to Refill Canon Pixma MG3550 Ink Cartridges: 手順 3、 3の画像 1 How to Refill Canon Pixma MG3550 Ink Cartridges: 手順 3、 3の画像 2 How to Refill Canon Pixma MG3550 Ink Cartridges: 手順 3、 3の画像 3
    • Remove the sticker label on the cartridge.
    • After removing the label, you will see a hole.
    • The black ink cartridge has one hole, and the color ink cartridge has three holes.
  4. How to Refill Canon Pixma MG3550 Ink Cartridges: 手順 4、 2の画像 1 How to Refill Canon Pixma MG3550 Ink Cartridges: 手順 4、 2の画像 2
    • For the black ink, first draw the ink into the syringe then insert the ink into the hole.
  5. How to Refill Canon Pixma MG3550 Ink Cartridges: 手順 5、 2の画像 1 How to Refill Canon Pixma MG3550 Ink Cartridges: 手順 5、 2の画像 2
    • The color ink cartridge will have three holes, one on the top and two on bottom.
    • Insert the red ink into the top hole.
  6. How to Refill Canon Pixma MG3550 Ink Cartridges: 手順 6、 2の画像 1 How to Refill Canon Pixma MG3550 Ink Cartridges: 手順 6、 2の画像 2
    • Insert the yellow ink into the bottom right hole.
  7. How to Refill Canon Pixma MG3550 Ink Cartridges: 手順 7、 2の画像 1 How to Refill Canon Pixma MG3550 Ink Cartridges: 手順 7、 2の画像 2
    • Insert the blue ink into the bottom left hole.
  8. How to Refill Canon Pixma MG3550 Ink Cartridges: 手順 8、 3の画像 1 How to Refill Canon Pixma MG3550 Ink Cartridges: 手順 8、 3の画像 2 How to Refill Canon Pixma MG3550 Ink Cartridges: 手順 8、 3の画像 3
    • Put the sticker label backs, place the cartridges back in the printer and close the lid.
    • Now you can start printing.
ゴール
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Kayun Kim
メンバー登録日: 03/24/23
277 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team 51-10, Peters Spring 2023 University of Memphis, Team 51-10, Peters Spring 2023人のメンバー
UM-PETERS-S23S51G10
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 70
過去 30 日: 113
今までの合計 1,176
