メインコンテンツにスキップ
How to Fix a Razer Naga Trinity Click Button
Haoran Ke
Haoran Ke とその他 人の作成者
最終更新日: October 2, 2024
30 - 40 分
中レベル
空欄の手順
Use this guide to fix the broken clicker in your Razer Naga Trinity gaming mouse.
Each mouse has a fixed maximum number of clicks. When the mouse is used for a long time, the clicker of the mouse will have problems. At this time, you will need to manually disassemble the mouse for maintenance.
Make sure you do not use too much force; the parts inside the mouse are sometimes very easy to damage.
This guide is not only applicable to this model,—other mice can also be repaired with this guide, but the internal structure may be different.
必要な工具と部品
これらのリンクを通じて購入すると、iFixit は手数料を得ます。
  1. How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: 手順 1、 3の画像 1 How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: 手順 1、 3の画像 2 How to Fix a Razer Naga Trinity Click Button, How to Fix a Razer Naga Trinity Click Button: 手順 1、 3の画像 3
    • Remove the three pads from the bottom of the mouse.
    • Remove the four screws beneath the pads using a JIS #1 screwdriver.
  2. How to Fix a Razer Naga Trinity Click Button: 手順 2、 2の画像 1 How to Fix a Razer Naga Trinity Click Button: 手順 2、 2の画像 2
    • Press the top of mouse and pull back to disconnect the mouse shell.
    • Pull out the cord that connects the RGB button.
  3. How to Fix a Razer Naga Trinity Click Button: 手順 3、 2の画像 1 How to Fix a Razer Naga Trinity Click Button: 手順 3、 2の画像 2
    • Remove the right shell.
    • Disconnect the cable connecting the left shell to the mouse.
    • Remove the left shell.
  4. How to Fix a Razer Naga Trinity Click Button: 手順 4、 1の画像 1
    • Use a safety pin to unlatch the clicker buttons.
  5. How to Fix a Razer Naga Trinity Click Button: 手順 5、 2の画像 1 How to Fix a Razer Naga Trinity Click Button: 手順 5、 2の画像 2
    • Insert the open safety pin to lift one side latch slightly.
    • Do not open the whole part.
    • Repeat for the other side.
  6. How to Fix a Razer Naga Trinity Click Button: 手順 6、 3の画像 1 How to Fix a Razer Naga Trinity Click Button: 手順 6、 3の画像 2 How to Fix a Razer Naga Trinity Click Button: 手順 6、 3の画像 3
    • Remove the clicker and white pin.
    • Gently press the middle part of the copper sheet until it unhooks itself.
    • Pull the bended part of the copper sheet back.
  7. How to Fix a Razer Naga Trinity Click Button: 手順 7、 1の画像 1
    • Reassemble the copper sheet with the white pin seated properly.
    • Push the spring down into its place using a spudger.
    • You will hear a click sound if you successfully assemble it.
終わりに
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Haoran Ke
メンバー登録日: 01/13/22
283 ポイント
1ガイドが承認済み
チーム
York University, Team S-12, Woodhouse Winter 2022 York University, Team S-12, Woodhouse Winter 2022人のメンバー
YORK-WOODHOUSE-W22SSG12
1 メンバー
4のガイドは作成済み
コメント 1 件
On the latest version of the mouse, the clicker button can no longer be opened...
Jérémie PLAYOUT - 返信
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 81
過去 30 日: 286
今までの合計 11,576
