メインコンテンツにスキップ
How to Fix a Noisy/Squeaky Bicycle Chain
Jiaming Liu
Jiaming Liu とその他 人の作成者
最終更新日: December 14, 2020
20 - 45 分
とても簡単
This guide will show you how to fix a noisy or squeaky bicycle chain. Bicycle chains tend to make squeaking noises due to a buildup of rust. To prevent your bicycle chain from rusting, store your bicycle indoors where it will not be exposed to frequent sun or rain.
Only use WD-40 that is made specifically for bicycles; regular WD-40 can damage your bicycle chain.
  1. How to Fix a Noisy/Squeaky Bicycle Chain, How to Fix a Noisy/Squeaky Bicycle Chain: 手順 1、 3の画像 1 How to Fix a Noisy/Squeaky Bicycle Chain, How to Fix a Noisy/Squeaky Bicycle Chain: 手順 1、 3の画像 2 How to Fix a Noisy/Squeaky Bicycle Chain, How to Fix a Noisy/Squeaky Bicycle Chain: 手順 1、 3の画像 3
    • Place a piece of cardboard under the bicycle to catch excess cleaner.
    • Rotate the foot pedal with your hand slowly, and spray WD-40 bicycle chain cleaner evenly throughout the chain.
    • Only use WD-40 that is specifically made for bicycles. Using normal WD-40 can damage your bicycle chain.
    • The chemical spray is toxic and very unpleasant to smell. Please use a mask or other means of protection on your face and eyes.
  2. How to Fix a Noisy/Squeaky Bicycle Chain: 手順 2、 3の画像 1 How to Fix a Noisy/Squeaky Bicycle Chain: 手順 2、 3の画像 2 How to Fix a Noisy/Squeaky Bicycle Chain: 手順 2、 3の画像 3
    • Use bicycle cleaning tools to clean the bicycle chain, the chainrings, the cogset, and front & rear derailleurs until most of the rust is gone.
    • Some bicycles do not have all of these parts.
  3. How to Fix a Noisy/Squeaky Bicycle Chain: 手順 3、 2の画像 1 How to Fix a Noisy/Squeaky Bicycle Chain: 手順 3、 2の画像 2
    • Check your chain system, not only on the chain, but also on the chainrings, cogset, and derailleur system. Sometimes this part will also make noises because of rust.
    • Drip the WD-40 bicycle lubricant on one spot of the chain and rotate the foot pedal until the whole chain is lubricated.
    • Repeat this process until the chain no longer squeaks.
ゴール
作成者
1人の作成者と共同作成されました。
Jiaming Liu
メンバー登録日: 09/19/20
97 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G12, Melo-Thaiss Fall 2020 York University, Team S1-G12, Melo-Thaiss Fall 2020人のメンバー
YORK-MELO-THAISS-F20S1G12
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 24
今までの合計 2,462
