メインコンテンツにスキップ
How To Stop Sony HDR-CX240E Screen From Moving
Stratos Thivaios
Stratos Thivaios とその他 2 人の作成者
最終更新日: May 7, 2024
45分 - 1時間
中レベル
コミュニティメンバーによる寄稿ガイド
Sometimes, the LCD screen on Sony Handycam camcorders, can start wiggling. Essentially, what happens is that the hinge gets unscrewed from the rest of the camera, causing the screen to wiggle and not feel "sturdy".
必要な工具と部品
ツール
もっと見る
  1. How To Stop Sony HDR-CX240E Screen From Moving, Unscrewing The Right Panel: 手順 1、 1の画像 1
    • Unscrew the 2 Phillips #00 screws on the right side of the camera.
  2. How To Stop Sony HDR-CX240E Screen From Moving, Unscrewing the bottom: 手順 2、 1の画像 1
    • Unscrew the 4 Phillips #00 screws form the bottom of the camera.
  3. How To Stop Sony HDR-CX240E Screen From Moving, Removing The Battery Compartment Cover: 手順 3、 1の画像 1
    • Remove the battery compartment cover by pulling it while "wiggling" it. It works like a hook.
  4. How To Stop Sony HDR-CX240E Screen From Moving, Unscrewing The Left Panel: 手順 4、 2の画像 1 How To Stop Sony HDR-CX240E Screen From Moving, Unscrewing The Left Panel: 手順 4、 2の画像 2
    • Unscrew the 2 Phillips #00 screws from the left side.
    • Unscrew the Phillips #00 screw from the small SD and HDMI compartment on the left side.
  5. How To Stop Sony HDR-CX240E Screen From Moving, Removing The Small Back Panel: 手順 5、 1の画像 1
    • Using the opening tool, remove the small panel at the back of the camera.
    • Always be careful when removing any panel, so you don't break any clips.
  6. How To Stop Sony HDR-CX240E Screen From Moving, Removing The Right Panel: 手順 6、 1の画像 1
    • Carefully use the opening tool or guitar picks to remove the entire right panel from the camera.
  7. How To Stop Sony HDR-CX240E Screen From Moving, Removing The Right Lens Small Panel: 手順 7、 1の画像 1
    • Pry the tiny panel off of the left side of the lens, between the lens and the screen hinge, revealing the hinge.
  8. How To Stop Sony HDR-CX240E Screen From Moving, Removing The Lens Ring And Cover Ring: 手順 8、 1の画像 1
    • Remove the plastic lens cover, and then remove the inside black "ring" that also contains the lens protector.
  9. How To Stop Sony HDR-CX240E Screen From Moving, Removing The Last Lens Ring And Mic: 手順 9、 1の画像 1
    この手順で使用する道具:
    • Remove the last ring from around the lens, very carefully as the microphone is on it, which is connected with a ribbon cable to the camera.
    • Remove the ring carefully, since it is connected to the motherboard with a ribbon cable.
    • Then, use a pair of tweezers to carefully disconnect the ribbon cable from the board.
  10. How To Stop Sony HDR-CX240E Screen From Moving, Separating The Two Parts Of The Camera: 手順 10、 1の画像 1
    • Unscrew the Phillips #00 screw from the left side of the lens, next to the hinge.
  11. How To Stop Sony HDR-CX240E Screen From Moving, Removing The Lens: 手順 11、 1の画像 1
    • Unscrew the 3 Phillips #00 screws from around the lens of the camera.
    • Then, remove the lens using your tweezers.
    • Handle the lens with caution as it's fragile.
    • It might be a good time to clean the lens with a microfiber cloth since you've already opened the camera.
  12. How To Stop Sony HDR-CX240E Screen From Moving, Screwing The Hinge: 手順 12、 1の画像 1
    • Tilt the camera to the side of the screen.
    • Pull apart the 2 sides of the camera to make some space.
    • Don't pull the 2 sides apart with too much force!
    • Using your Phillips #00 screwdriver, carefully screw tightly the 2 screws that hold the hinge on the camera.
    • You will need to use your screwdriver "diagonally" (not straight), since having clear access to the screws would require a lot more disassembly.
終わりに
作成者
2人の作成者と共同で作成されました。
Stratos Thivaios
メンバー登録日: 02/27/23
1,305 ポイント
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 9
今までの合計 337
